How long did your lt1 last?
Re: How long did your lt1 last?
JESUS, after seeing some of these LT1's that have lasted deep into the 200k+ mark I feel sorry for those that broke their crank or spun a rod.
cjmatt= I really hope you are joking about the stuff in your sig.
1994 Trans Am GT Type-R, 6-Speed, Vortex Air Spinner, NOS Octane Booster, Hydrogen Filled Tires, Ebay Electric Supercharger, Chrome Rims, Chrome Shifter, Red Cold Air Induction
91k.... cam install... and downhill from thre like another guys did also... thigns started messgin up.. first the opti.. the it went all to ****...fryed some rings... spun a rod... blah blah ablh.... i guess a agressive cam and a 100 shot will do that
80,000 miles w/ bolt-ons...worn out thrust bearing, wobbling crank shaft. granted the car still starts, just the crank position sensor cant read the crank sometimes so it turns off. there was about .25-.5 wobble
, who knows how long it would have lasted after that.
there were about 60-70 drag strip runs, 50 or so street races, and numerous times i did donuts in the rain. I took good care of it maintanance wise, but really beat on it a lot, and its my fault, i take full responsibility.
the new 355 will be a different story, Im going to be nice to her.
, who knows how long it would have lasted after that.there were about 60-70 drag strip runs, 50 or so street races, and numerous times i did donuts in the rain. I took good care of it maintanance wise, but really beat on it a lot, and its my fault, i take full responsibility.
Last guy who had it 100k before rod knock. Bought the car and I replaced it with a trans am motor with 40k on it. Currently at around ~70k on the motor. Went through 4 opti's. Blew the 10 bolt once within an hour after getting new tires. Replaced the wp once. Bunch of other small fixes etc. However now when it gets cold (pretty much less than 40 degrees) it leaks coolant from between the head and the block right on top of my opti which was causing my opti failures. When I get the opportunity to rip the heads off to replace the headgaskets gonna have them checked out for flatness. Maybe throw in some port work while I'm at it
mine is at 89.5K miles and it runs really strong.
