How long did your lt1 last?
Old Jul 24, 2006 | 03:58 PM
  #16
arcticz28the383's Avatar
Re: How long did your lt1 last?
Yeah, mine broke in half the night i put in my lt4 springs and 1.6rr's. I thought I dropped a valve and was beating myself over it for a month before i tore it apart and found the crank broke right behind the 5 and 6 rods..
Old Jul 24, 2006 | 04:09 PM
  #17
SweetZRag's Avatar
310,000 miles and still runs like new! Just rebuilt A4 but all else is original.
Old Jul 24, 2006 | 04:37 PM
  #18
StephenDeli22's Avatar
Old Jul 24, 2006 | 04:38 PM
  #19
94Camaro_Z_28's Avatar
141,000 and was running strong. Dropped the tranny and figured I might as well freshen the motor while I was at it. Not a leak of anything(other than the rear intake oil leak). Looked like it could've run for another 200,000 without an issue.
Old Jul 24, 2006 | 04:39 PM
  #20
BUBBA's Avatar
7000 miles ---went to hell right after cam and head install.
Old Jul 24, 2006 | 04:45 PM
  #21
CamaroZBoy's Avatar
In your sig...I see you went through some opti's? What was that all about...explain please.
CC
Old Jul 24, 2006 | 04:59 PM
  #22
yournamehere's Avatar
Bought my '96 Z28 used with 94,000, clean inside and out. Drove
it for seven months, maybe 2,500 miles and without warning
it got hot and chewed up a head gasket on the expressway.
No oil in the coolant that I could tell, and no coolant in the
oil that I can see.
When it cools off a little bit here I'll take it apart and replace
the head gaskets, have a valve job done and the heads
checked for flatness.
So, in closing, I've been paying for over 1 1/2 years ( 2 1/2 to go )
for a car I've driven 7 months.
I must be posessed.
Old Jul 24, 2006 | 05:34 PM
  #23
marshall93z's Avatar
267,000 with stock opti.
Old Jul 24, 2006 | 05:36 PM
  #24
Lt1dtpower's Avatar
75000 and still running strong. Been running nitrous since 99. Le1 set up with 150 shot for a few years. My buds 93 has 175000 with all the bolton still runnig strong. My brother has 94000 on his 93.
Joe
Old Jul 24, 2006 | 07:04 PM
  #25
1BigBird3's Avatar
(95 Z History)
1st motor went 89k (minor bolt-ons) = Blown Headgasket
2nd motor went 2k (minor bolt-ons) = Bent Valves
3rd motor went 8k (full bolt-ons) = Skipped 4 Teeth on a OEM Timing Chain Setup
(94 Z History)
1st motor went 98k (full bolt-ons) = Coolant Coming out the Exhaust
Said to hell with it and finally started doing the work myself and never cut a corner.
383 and 355 both are now running strong.
Ruben F.
Old Jul 24, 2006 | 07:16 PM
  #26
Cmr0z28's Avatar
101k with about 15 bottles of nitrous through it and ~5k miles on the cam install with no problems.
Old Jul 24, 2006 | 07:38 PM
  #27
CamaroZBoy's Avatar
Really nothing has broke on your car? Not even weird things? Pretty cool dude
CC
Old Jul 24, 2006 | 07:58 PM
  #28
GT KILLER's Avatar
123xxx and still pulls real hard. I believe the previous three owners took excellent care of the engine (I know for a fact the guy right before me did). My bay was flawless when I bought it (and still is for the most part). Looking at my engine you wouldn't believe it has that much on it. There were 116xxx on it at time of my purchase (May '05).
Old Jul 24, 2006 | 08:09 PM
  #29
Steve in Seattle's Avatar
Thumbs up Re: How long did your lt1 last?
235,000 miles (including ~100 passes down the strip, and some "spirited" driving habits).
Factory-installed opti.
Guess they finally got it right in '97.
I'm hoping this one'll last till 250,000 (1 year commuting) till I can drop in the stroker.
Now the 10-bolt was a different story... 2 diff's toasted... and I love my Moser 12-bolt and Street Twin clutch.
Old Jul 24, 2006 | 08:13 PM
  #30
Originally Posted by 1BigBird3
(95 Z History)
(94 Z History)
Said to hell with it and finally started doing the work myself and never cut a corner. 383 and 355 both are now running strong.
Ruben F.
Damn... I'd swear I was cursed if I had 3 engines die within 10,000 miles.
Glad to hear things are runnin' good now. Did you have 1 shop doing all the installs before? or were they different shops and it was just a bad coincidence?
