How long did your lt1 last?
Old Jul 25, 2006 | 12:43 PM
  #46
hotrod18_69's Avatar
Re: How long did your lt1 last?
115K and still kicking, cam starting cam install next week
Old Jul 25, 2006 | 01:07 PM
  #47
SteveR's Avatar
253k on my white '94. Just pulled the heads for a valve job. Before that, I had never even removed a valve cover.
Old Jul 25, 2006 | 01:32 PM
  #48
CJ Black LS1 Z28 M6's Avatar
JESUS, after seeing some of these LT1's that have lasted deep into the 200k+ mark I feel sorry for those that broke their crank or spun a rod.
Old Jul 25, 2006 | 02:05 PM
  #49
AZ2ENVY's Avatar
cjmatt= I really hope you are joking about the stuff in your sig.
1994 Trans Am GT Type-R, 6-Speed, Vortex Air Spinner, NOS Octane Booster, Hydrogen Filled Tires, Ebay Electric Supercharger, Chrome Rims, Chrome Shifter, Red Cold Air Induction
Old Jul 25, 2006 | 02:32 PM
  #50
Tsar's Avatar
167k still running strong.
Old Jul 25, 2006 | 02:52 PM
  #51
white93lt1's Avatar
91k.... cam install... and downhill from thre like another guys did also... thigns started messgin up.. first the opti.. the it went all to ****...fryed some rings... spun a rod... blah blah ablh.... i guess a agressive cam and a 100 shot will do that
Old Jul 25, 2006 | 04:25 PM
  #52
rasputin's Avatar
80,000 miles w/ bolt-ons...worn out thrust bearing, wobbling crank shaft. granted the car still starts, just the crank position sensor cant read the crank sometimes so it turns off. there was about .25-.5 wobble , who knows how long it would have lasted after that.
there were about 60-70 drag strip runs, 50 or so street races, and numerous times i did donuts in the rain. I took good care of it maintanance wise, but really beat on it a lot, and its my fault, i take full responsibility.
the new 355 will be a different story, Im going to be nice to her.
Old Jul 16, 2007 | 08:02 PM
  #53
11secgen's Avatar
120k, and rip as of last weekend. of a 100 dry shot killed the head gasket,so i guess it isnt 100% dead, but might as well freshen it up now.
Old Jul 16, 2007 | 10:39 PM
  #54
Whitey13's Avatar
178,000 and a blown head gasket. In the process of fixing that.
94 Z28
Old Jul 16, 2007 | 11:02 PM
  #55
CamaroZBoy's Avatar
150,000 Miles...still running. No major fixes to this point
Stock opti, gone through a couple alternators and water pumps.
Old Jul 17, 2007 | 12:05 AM
  #56
Z28LT1_Just_Nasty's Avatar
Last guy who had it 100k before rod knock. Bought the car and I replaced it with a trans am motor with 40k on it. Currently at around ~70k on the motor. Went through 4 opti's. Blew the 10 bolt once within an hour after getting new tires. Replaced the wp once. Bunch of other small fixes etc. However now when it gets cold (pretty much less than 40 degrees) it leaks coolant from between the head and the block right on top of my opti which was causing my opti failures. When I get the opportunity to rip the heads off to replace the headgaskets gonna have them checked out for flatness. Maybe throw in some port work while I'm at it
Old Jul 17, 2007 | 01:00 AM
  #57
Phatcaprice's Avatar
180k and some change - Iron Head LT1
Still pulls hard for a Caprice with 1.6rr, Cone filter and flowmasters.
Old Jul 17, 2007 | 06:50 AM
  #58
scott9050's Avatar
148K on a completely stock engine. Pulls strong and burns no oil, though it leaks some.
Old Jul 17, 2007 | 11:39 AM
  #59
JoeliusZ28's Avatar
ive seen the car in person. i think 'ebay electric supercharger' is a bit of an understatement
mine is at 89.5K miles and it runs really strong.
Old Jul 17, 2007 | 11:43 AM
  #60
NotACop97z28's Avatar
131xxx, one opti, one water pump, ran into some money an bought a 383 shortblock curently 200miles on it I still have the original motor sitting in my Garage, hopefully not for long
