How long did your lt1 last?
Old Jul 24, 2006 | 08:13 PM
  #31
1FstFormulaV8's Avatar
Re: How long did your lt1 last?
100k+ miles. 2 Transmissions. 3 Opti-Sparks. Still running strong, needs a tuneup.
Old Jul 24, 2006 | 08:20 PM
  #32
pgm's Avatar
pgm
My 95 Z28 had a junk motor when I bought it, 127K miles. I don't think the guy ever changed the oil, there was ~1/4" of sludge built up in the heads and lifter valley.
#2 main bearing spun, #3 rod bearing shredded beyond recognition, and #6 rod bearing spun. Also the #1 top ring was broken in half, probably from low octane gas.
Old Jul 24, 2006 | 08:35 PM
  #33
LastZ4ME's Avatar
11 Years but only 76,000 miles. Lots of 1/4 mile passes. Original Opti. everything still works on the car, engine feels just as strong as ever
Old Jul 24, 2006 | 10:48 PM
  #34
revtime's Avatar
162k and it bounces off the limiter every shift when racing....I need a shift lite bad now with the TH400 and 4k stall.
Stock internals with LTs, K&N FIPK, Ed Wright tune, no HVAC, no power steering, Stock 10 bolt with 3.73s and a TA rear girdle.
Went through 1 opti, 1 water pump, and 2 trannies before I put the bulletproof one in.
I drive the living hell out of it but I also keep very good maintenance on it.
It will probably go over 200k pulling very low 13s.
Old Jul 24, 2006 | 11:41 PM
  #35
Misfits's Avatar
96,500kms and still pulls strong... 1 water pump, 1 heatercore, 1 opti-spark, 1 power steering pump.
Old Jul 24, 2006 | 11:49 PM
  #36
CJ Black LS1 Z28 M6's Avatar
previous 94 Z28 LT1 183,686 ran strong as hell all the bolt ons
current 94 Z28 115,000 just started running after replacing opti,wp,coil,starter,wires,plugs etc sat for 7 months because i gave my LS1 all my attention
Old Jul 25, 2006 | 12:01 AM
  #37
3DFORMULA's Avatar
1994 Formula---127,000 just broke cap and rotor, strong motor tho'
1996 Z/28--- 136,000 all original and strong runnin', gettin ready for its first pass
Old Jul 25, 2006 | 12:06 AM
  #38
OneFlyn95z28's Avatar
I got 36k out of my first one. It had a problem around 11Psi of boost
Old Jul 25, 2006 | 12:25 AM
  #39
N2O93Z28's Avatar
81,000 on stock motor w/ heads, cam, nitrous - oil pump failure
10,000 on 355 w/ same parts - connecting rod broke (stock rod)
400 miles on 391 - sold to fund 396
I used the money from the sale of the 391 to put down on my Silverado 4 1/2 years ago so I had to save up for the 396. Finally got her running about a month ago after getting married, buying a house and putting my wife through school. Its been a long time coming.
Old Jul 25, 2006 | 12:28 AM
  #40
Yeah It has been three years since I got Married and bought a house blah blah blah .
Sure puts a hit in the budget doen't it
Old Jul 25, 2006 | 12:38 AM
  #41
Vigilante's Avatar
153,400 when my last car spun a rod bearing.
Old Jul 25, 2006 | 08:49 AM
  #42
SweetZRag's Avatar
Originally Posted by CamaroZBoy
In your sig...I see you went through some opti's? What was that all about...explain please. CC
First Opti failed around 100K. My wife was driving on the expressway at about 75 mph and she got a hell of a backfire and the car was dead. It took the dealer a week and $1,600 to find the problem. They said the bushing was burned up.
The second time, the car stalled and was barely able to run. A lot of missing and backfire, weasing and bucking. DTC code was missing hi res signal. I nursed it home about 5 miles and put a new Opti in and problem solved. This was near 200,000 milies.
Third time I started getting a missing hi-res signal DTC light. This was around 275,000 miles.
At 310,000, I was getting a missing high res error again and just put in the MSD Opti. I am now having a hesitation problem so I am not ready to proclaim it a success yet. Still working on it.
Old Jul 25, 2006 | 11:49 AM
  #43
transam001's Avatar
when i got the car it have 14,000 miles. don't get me wrong i'm not easy on the car but, the crank braking is a bad crank from factory.
Old Jul 25, 2006 | 12:17 PM
  #44
1BigBird3's Avatar
Originally Posted by Steve in Seattle
Damn... I'd swear I was cursed if I had 3 engines die within 10,000 miles.
Glad to hear things are runnin' good now. Did you have 1 shop doing all the installs before? or were they different shops and it was just a bad coincidence?
It was indeed the same shop. Golden Wrench Automotive for those wishing to stay away.
The only time I felt anything close to "cursed" was when my 3rd 4L60E blew on my 95Z. I went to 3 different shops for 4L60E's. All of which lasted maybe 5k each. Again cuttin corners is not the way to go, you get what you pay for. So I cut a whole in my car and installed a T56. Haven't looked back since. Best mod I ever done.
I think my lady was happier then I when I got them up and runnin' and out of the garage for some fresh air.
Ruben F.
Old Jul 25, 2006 | 12:21 PM
  #45
cjmatt's Avatar
27k. 6psi boost
