Debris found in the oil pan.
Old Apr 3, 2007 | 05:20 PM
  #16
FASTFATBOY's Avatar
Originally Posted by blown383
You should be able to replace the front seals by removing the timing cover in under 2 hours. Thats if you don't rip the oil plan seal.
-B
Why would you remove the timing cover to replace the seals, especially if the engine is in the car?
David
Old Apr 3, 2007 | 06:37 PM
  #17
blown383's Avatar
David
Well the guy said that if his timing cover gasket was leaking in addition to the front seal.... how else would he replace them? Plus most people have enough trouble installing the front seal while the cover is off let alone on the car with the crank snout in the way.
-B
Old Apr 3, 2007 | 07:37 PM
  #18
12SCNDZ's Avatar
-B
You don't have to remove the front cover to get the seal out. You can get the seal out with a puller, or even a screwdriver by just pulling the damper.
Frank
CPT
Old May 28, 2012 | 05:26 PM
  #19
96HawkCnvt's Avatar
Re: Debris found in the oil pan.
Old post I know... But I had the same & wanted an opinion. I just installed a new seal & although I haven't looked yet, I concluded the same that I must have messed up the seal when I put the seal in. So... in my case only about 1/2 of the spring has been recovered so far. I intend to fill/drain again to try to get the remainder but what if I cannot get it that way? Will that little spring go anywhere other than the magnetic drain plug?
Thanks,
Todd
Old May 28, 2012 | 07:26 PM
  #20
96HawkCnvt's Avatar
Ok, well in case anyone has any ideas... it wasn't the front crank seal. And I compared the diameter of the spring found in the pan to the spring for the front crank seal. The spring found is a smaller diameter even then the one in the crank seal. I cannot think of what seal would have a smaller diameter spring (same type) and could be found in the oil pan. I thought maybe the old opti seal because it was missing, but checked a new seal and it is also without a spring.
Guess at this point I'll see if/where it leaks. Not sure what else to look at right now. Any thoughts appreciated...
Todd
Old May 31, 2012 | 11:52 AM
  #21
000-001's Avatar
I think the seal for the water pump drive has a tiny spring.
Old May 31, 2012 | 08:45 PM
  #22
MachinistOne's Avatar
The valve springs also have little springs on them...never seen one just fail though, had to of been damaged on installation first.
Old Jun 2, 2012 | 10:03 AM
  #23
Typo? Valve seals?
cmsmith
Apr 11, 2015 09:37 PM
BigWil
Mar 29, 2015 12:24 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
HuJass
18
Jun 24, 2002 09:19 PM
