22 lb fuel injectors
Re: 22 lb fuel injectors
93 LT1 is 22 #/HR. 94-97 are 24 #/Hr. If you install the 22's in a 94, the PCM should be reprogrammed for the new size.
If you don't program the PCM, it will try and adjust the long term fuel corrections to correct for the fuel shortfall caused by the "too small" injectors, but that becomes a bit hit-or-miss, depending on whether the long term fuel corrections are already elevated for some other reason.
I woudn't recommend using the 22's unless you have the PCM reprogrammed.
thank you,i see your profile pic if your a colts fan...i hope you guys beat the pats tommorow
thank you buddy im glad i asked you guys 1st before buying them.
Jul 4, 2005 05:00 PM
