Debris found in the oil pan.
Old Apr 1, 2007 | 12:30 PM
carolinacasper's Avatar
Hey guys, I found a broken spring in my oil pan when I changed the oil yesterday.
It is about 2 mm in diameter and about 2 inches long. Any ideas what this could be? The car runs great just as before and doesn't seem to miss the spring.
Old Apr 1, 2007 | 01:23 PM
MachinistOne's Avatar
Oil pump pressure spring would be my guess, look at the side of your oil pump...
Old Apr 1, 2007 | 06:01 PM
wrd1972's Avatar
Oil pump spring is way larger than 2mm in diameter and about 3 inches in length.
Old Apr 1, 2007 | 06:11 PM
mdacton's Avatar
need a pic
Old Apr 1, 2007 | 06:20 PM
jsetzer's Avatar
Spring on the oil bypass? Thats pretty tiny.
Old Apr 1, 2007 | 08:04 PM
Here is a picture of the spring with a penny for size comparison.
In the picture, the spring is broken in half and the hook on both ends of the spring is broken as well.
http://rides.webshots.com/photo/2283...54820759CMXldw
Old Apr 1, 2007 | 08:14 PM
Javier97Z28's Avatar
Moderator
I can't think of anything that uses a spring like that in the engine.
Drop a spring out of a tool or something?
Old Apr 1, 2007 | 08:20 PM
12SCNDZ's Avatar
That's a spring that goes inside of an oil seal. Got any major oil leaks? Front seal? Rear main seal?
Frank
CPT
Old Apr 1, 2007 | 08:21 PM
wrd1972's Avatar
That is a spring that is used in round seals to tighten around a given shaft to resist leak out. I suspect that came from the front crank seal or the rear crank seal. You should have a leak at one of those two places.
Moderator
Frank
CPT
Somebody's thinkin'!!!!
I was trying to think from the block up and couldn't think of anything, ding ding!
Old Apr 1, 2007 | 08:24 PM
ZL1modified's Avatar
kinda looks like one of those springs that comes with the locking header bolts... disregard I'm wrong...
did you ever have your engine apart? didn't even think about those springs...
Old Apr 1, 2007 | 09:17 PM
Hmm...have never seen one of those come out or break, that why I guessed he intended wire diameter and said oil pump spring. But yeah - only spring in a motor like that is a seal spring.
Old Apr 1, 2007 | 11:34 PM
Frank
CPT
The rear main seal is good, but the front main seal and/or timing chain cover gasket leaks a ridiculous amount.
Any estimates on how hard it is to replace both?
Old Apr 3, 2007 | 04:58 PM
blown383's Avatar
You should be able to replace the front seals by removing the timing cover in under 2 hours. Thats if you don't rip the oil plan seal.
-B
Old Apr 3, 2007 | 05:18 PM
FASTFATBOY's Avatar
Those springs are usually on double lip seals. If the seal was driven in with a hammer and got cocked and was driven on in..it is a common thing for this to happen.
David
