Debris found in the oil pan.
-B
Frank
CPT
Re: Debris found in the oil pan.
Old post I know... But I had the same & wanted an opinion. I just installed a new seal & although I haven't looked yet, I concluded the same that I must have messed up the seal when I put the seal in. So... in my case only about 1/2 of the spring has been recovered so far. I intend to fill/drain again to try to get the remainder but what if I cannot get it that way? Will that little spring go anywhere other than the magnetic drain plug?
Thanks,
Todd
Thanks,
Todd
Ok, well in case anyone has any ideas... it wasn't the front crank seal. And I compared the diameter of the spring found in the pan to the spring for the front crank seal. The spring found is a smaller diameter even then the one in the crank seal. I cannot think of what seal would have a smaller diameter spring (same type) and could be found in the oil pan. I thought maybe the old opti seal because it was missing, but checked a new seal and it is also without a spring.
Guess at this point I'll see if/where it leaks. Not sure what else to look at right now. Any thoughts appreciated...
Todd
Todd
cmsmith
Apr 11, 2015 09:37 PM
HuJass
18
Jun 24, 2002 09:19 PM
