Project BoostedROC....Iroc383LT1 Turbo Build.
Old Oct 5, 2009 | 06:21 PM
  #106
Orr89rocz's Avatar
Car is gonna be nasty with those heads. Changing the cam with this setup?
Old Oct 6, 2009 | 05:51 AM
  #107
jay_rich's Avatar
the cam is already a custom spec 230/236 114lsa cam, but i am tempted to get something that comes on harder.....im gonna stick with it and give it a shot for another season.
Jay
Old Oct 6, 2009 | 08:47 PM
  #108
Orr89rocz's Avatar
should be a good cam with that 383. My 233/233 is on a 112 for my 401 and it seems to work well so far... i've only seen 2.7 lbs of boost in the high 3000 rpm range with heavy part throttle and its already coming alive.
Old Oct 6, 2009 | 08:59 PM
  #109
jay_rich's Avatar
I see 8psi by 4000 i think...if i recall, I try to pay attention to the road bc it breaks loose thru all the gears hahah, second is really fun!
I also found a huge leak just before I found out the head cracked so that coulda had some reason for the slower spool.
I redid the crossover in 1/8inch and moved the wastegate lower.
Jay
Old Oct 21, 2009 | 04:20 PM
  #110
jay_rich's Avatar
Well some more parts in hahaha.
As you see my Ported AFR's are in. They are dissasembled so I can hot tank them and mill them to ensure they are 100% true.
AFR 195's
2.055/1.600 valves
Ported.
FLOW INT EXH
.100 71.7 52.8
.200 143.4 105.5
.300 208.6 147.2
.400 247.3 185.5
.500 276.3 203.4
.600 293.7 208.5
.650 299.1 211.3
Ordered some 16awg 1 5/8 bends with the collectors to build some tubular headers ...it is a weld up kit, but I bought it for the 90's basically. So it wont go together as the kit is suppose to. It was just alot cheaper to buy a kit then to buy separate bends.
Also I designed some SBC round port flanges using the LT1 bolt pattern at work, then CNC and surface ground them
The turned out perfect, I bolted them to the AFR's and the ports line up mint!
Jay
Old Oct 21, 2009 | 04:25 PM
  #111
DirtyDaveW's Avatar
AFR 195's
2.055/1.600 valves
Ported.
FLOW EXH INT
.100 71.7 52.8
.200 143.4 105.5
.300 208.6 147.2
.400 247.3 185.5
.500 276.3 203.4
.600 293.7 208.5
.650 299.1 211.3
Good flow's there brother!
Dang! Nice! What are they made out of? Stainless?
Old Oct 21, 2009 | 04:28 PM
  #112
jay_rich's Avatar
Thanks i posted the flow backwards hahah changed my post :P
They are made of just P20 mild steel
Jay
Old Oct 21, 2009 | 04:52 PM
  #113
DirtyDaveW's Avatar
How much would it cost me to buy a pair of those flanges like those from you?
Thanks!
Dave
Jay
Old Oct 21, 2009 | 05:13 PM
  #114
jay_rich's Avatar
Thanks!
Dave
hmm well with material costs and since I dont run a CNC anymore (got a desk job now with higher pay haha). I have to send them to a buddies shop.
Im sure we could do them for around 80-90 a pair plus shipping.
I would have to probably make about 10 pairs to actually drop the price etc.
But if I can get my hands on a machine sometime when Im not working I could probably make a few and not have to worry about paying my friend to cnc them.
I will talk with him and see how long it took him to cut them and how much he wants. He cnc'd mine as a favor, bc I am tuning his boosted LT1 when he is done (he is buiding a roots setup)
Jay
Old Oct 21, 2009 | 06:06 PM
  #115
DirtyDaveW's Avatar
Very cool. Let me know if you can get them. I'm fine with that 80 to 90 + shipping.
Thanks for the quick reply.
Dave
Jay
Old Oct 21, 2009 | 06:08 PM
  #116
jay_rich's Avatar
Dave
okay whats your address. I will look into it all this week for ya.
Jay
Old Oct 21, 2009 | 06:25 PM
  #117
DirtyDaveW's Avatar
Zip is 12060
East Chatham, NY.
Jay
Old Oct 27, 2009 | 10:11 PM
  #118
jay_rich's Avatar
Well I started on the tubular headers, took about 2H total maybe so far to get this far.
Seems to be working good!
Jay
Old Oct 27, 2009 | 10:49 PM
  #119
reamo04's Avatar
jay, like i said on TTF, be sure to weld the pipes together before you weld the collectors on
Old Oct 28, 2009 | 06:05 AM
  #120
jay_rich's Avatar
yea i already know all that, as there is big gaps to fill there :P, I may take them to a buddy to finish tig them.
Jay
