Scan9495: Free OBD1 scan app for 93/94/95 LT1
Old May 18, 2024 | 06:54 AM
  #571
chevykid's Avatar
Re: Scan9495: Free OBD1 scan app for 93/94/95 LT1
Originally Posted by antic
Thanks for the help, I have ordered the products.
On your old post of the inside of the cable and you wrote that "black goes to pins 4 and 5" but in the picture itself it doesnt seem like black is connected to 4 and 5? Image below
the black is going to the center of the circuit board that uses the circuit board traces to connect to those pins.
Old May 24, 2024 | 01:27 PM
  #572
antic's Avatar
I ordered the parts and soldered the wires and everything works perfectly, I read the codes without problems.
Thank you so much for the help.
Old May 24, 2024 | 03:39 PM
  #573
chevykid's Avatar
good job!
Old Jan 23, 2025 | 05:19 PM
  #574
Mnp40c's Avatar
Hi all! This is my 1st post. I need help. I have a 1995 Z28 I am trying to use Scan9495 to diagnose, and cannot get the software to connect to the car. I went on Amazon and bought the cable below. Wired it to a 16 pin obd2 connector just as Gary described (pins 4&5 to black / and pin 9 to the green and white wires). When I plug the cord into my computer it recognizes the cord as a usb serial device and puts it on COM3. When I launch the software and click connect it attempts to connect but fails. I tried different drivers to no avail. I am running the program in comparability mode for win 7, although my computer itself is windows 11. What am I doing wrong, am I just screwed, and out the $$ spent making this cable?
I would really like to get the airbag codes to diagnose, and clear the engine light. Please help, or let me know how else I can accomplish this using a different software?
cable I bought on Amazon is pictured below as well as the ODB2 port on my 1995 Z.
Old Jan 24, 2025 | 01:08 AM
  #575
Not familiar with that cable. Gary gave up on the cheap Chinese components, and pretty much recommended buying a complete cable from a reliable source.
https://obd2allinone.com/aldl.asp
Unfortunately he no longer frequents this site.
@GaryDoug
Old Jan 24, 2025 | 01:13 AM
  #576
Mnp40c's Avatar
I think I realized my error, I’m supposed to solder the blue/white cables to pin 9, correct? Looks like those wires are the RXD and TXD? I just saw Gary said green/white which doesn’t match this cable I bought on Amazon. Green and white on this cable I bought are RXD and RTS. I’m going to try the other way and see if that works. I’ll follow up tomorrow as I bought a new cable that’s being delivered tomorrow since I sort of jacked this one up.
Old Jan 24, 2025 | 01:34 AM
  #577
GaryDoug's Avatar
Prominent Member
I think you are doing the right thing, It's late here so I am not sure but carry on.
Old Jan 24, 2025 | 03:45 PM
  #578
Mnp40c's Avatar
Thank you Gary! So all is good, and I’m now able to read codes on my 95 Camaro. I was able to solder a new cable I got off Amazon and it works great! Had to solder the RXD and TXD to pin 9, then ground to pins 4/5. In my case the wires for pin 9 were yellow and orange.
I created a separate post to discuss the DTCs I’m getting on my 52k mile 95 z28.
Old Jan 24, 2025 | 08:40 PM
  #579
Glad it worked out.
If anyone wants to offer help with the codes, please use the new thread in this Computer Diagnostics…. forum.
https://www.camaroz28.com/forums/com...8-70-a-890187/
Old Mar 24, 2026 | 11:34 AM
  #580
stngh8r's Avatar
Thank you Gary
94Z28LS1toLT1
Dec 24, 2024 12:00 PM
aj2494
Mar 12, 2015 10:17 PM
bazzi
Aug 29, 2012 08:32 PM
streetrat129
Oct 13, 2003 12:55 PM
jammer
Jun 30, 2003 12:01 PM
