Engine Swap Thread. V6 to...?
Old Feb 14, 2005 | 02:12 PM
  #76
96camarors's Avatar
Re: Engine Swap Thread. V6 to...?
Swap is done. Actually, it was done about 2 months ago, but I'm just now getting around to posting pictures of it. Everything is running smoothly
http://www.bluemstudios.com/camaro_rs_3.jpg
http://www.bluemstudios.com/96rs.jpg
Old Feb 15, 2005 | 04:51 PM
  #77
twhill's Avatar
Big block 454
I have a 95 3.4L v6 and I am thinking about swapping it for a 454 big block, and I was wondering if it would fit, do you guys think it would fit?
Old Feb 15, 2005 | 09:37 PM
  #78
NOS2006's Avatar
I doubt it, but I could definitely be wrong... Maybe you can pull it off...
Old Feb 15, 2005 | 11:43 PM
  #79
Black94Camaro's Avatar
anything can fit ... just takes money
Old Feb 28, 2005 | 09:10 AM
  #80
Sergio's Avatar
Hm.. the engine harness that i disconnected from my complete 1994 Lt-1 (M6) engine has 4 connectors on the very end:
- 1 wide black connector with just 4 wires (of which one Thick purple wire, starter ?)
- 1 white connector with about 12 wires
- 1 blue connector with about 10 wires
- 1 narrow and small flat connector with just 3 wires
In the stories i hear about just 2 connectors ?
My car is a 95 3.4 M5 ....
One of the things that's even unclear in the factory workshop manuals is the way harnesses are placed. They are extremely unclear and it's hard to figure out what is meant by forward harness, engine harness, etc.
It might be EXTREMELY helpfull if somebody could draw the harnesses (schematic) on paper and i'm willing to draw them digitally with colors to make it all clear and post it here on the board.
As for the 94 and 95 engine harness being identical, not in my case.
The colors not always match (i have just a 95 Fbody manual that also cover the V8 engine and harness).
Old Feb 28, 2005 | 10:33 AM
  #81
95wannabe's Avatar
http://shbox.com/1/schematics_wiring.html
click on item #1 & #2, that should help you out
Old Feb 28, 2005 | 02:54 PM
  #82
Sergio's Avatar
You da MAN !!!!!!!!!!!!! Bowing down.
Been wondering about this info for so long.
Ok, those connectors are identified as:
C210
C220
C230
A/C Evap temp sensor
It's all clear to me now.
People, i WILL document the swap from A to Z and make the most comprehensive walkthrough possible, and you that's a promise !
Next i'll email and Thank that guy is made that great info and put it online !
Old Mar 8, 2005 | 10:52 PM
  #83
GMH94Z28's Avatar
I currently have a 94 Z28 that has some body damage and i came across a straight body 95 v6 camaro that i can pick up cheap. My question is do i have to put all of my 94 Z wiring harness in the 95 v6 camaro to make it work? I know i am going to have to install the 94 Z engine wiring harness in there to make it work but i am unsure of putting all the inside of the car wiring harness in there. I have done it before and it sucked. Thanks
Old Mar 9, 2005 | 02:56 AM
  #84
Klypto's Avatar
i just totalled my 00 z28, looking for a 98+v6 to swap into it.. msg me if have one for cheap.. motor can be blown, and any part of the drivetrain! i just need a shell! pics of wrecked car in sig...
cory
Old Mar 9, 2005 | 02:40 PM
  #85
95wannabe's Avatar
I did the same year swap as you, and no, I didn't change out any of the under dash wiring harness. However, I did have to move/add a couple of wires in the passenger side kick panel...anything you need to know is on shoebox's site
Old Mar 9, 2005 | 04:13 PM
  #86
GMH94Z28's Avatar
"I did the same year swap as you, and no, I didn't change out any of the under dash wiring harness. However, I did have to move/add a couple of wires in the passenger side kick panel...anything you need to know is on shoebox's site"
What wires did you have to move/add? Thanks for the reply
Old Mar 9, 2005 | 04:26 PM
  #87
95wannabe's Avatar
GEEZ, it's been a while. I'll have to look at the car to tell you for sure. I think I had to run 12v down to one of these connectors for the fuel pump. click on the tabs at the bottom of the page...C210, c220, c230 It will show you everything that needs to be there. http://shbox.com/1/harness_connector_faces.htm
Old Mar 13, 2005 | 02:30 PM
  #88
Sergio's Avatar
Anybody that can tell me the deal with the V6 Vs V8 intank fuel pump ???
- exact same pump ?
- more than enough to supply a modded Lt-1 with large injectors ?
Anybody ?
Old Mar 13, 2005 | 05:34 PM
  #89
Klypto's Avatar
i was thinking about that same problem on my LS1 swap.....
cory
Old Mar 16, 2005 | 01:47 PM
  #90
Sergio's Avatar
Come on people, help us out ...
It's funny to see that half a dozen have done it, some even at a bargain (so they claim), yet when specific questions are asked nobody seems to read or answer them.
I WILL be documenting everything and keep a FULL LIST of all parts used and a CD full with pictures, hate to see people reinventing the wheel again.
And that's a promise.
