The LT1 is a torque monster compared to the weak a** 4.6.
Re: The LT1 is a torque monster compared to the weak a** 4.6.
that was a 12.9 not a 12.8 pass bob.
just busting your *****.
you werent in nj last week were you?
i saw a brand new red cobra with VA plates.it was parked for awhile so i didnt see who owned it.
Read the article my friend....the early one went 12.89 (in good air), the SS that is pictured went 12.96.
I was in NJ (Atco) two weeks ago for the NMRA race, but we got rained out. Sucked, as I had the opportunity to sew up points in Factory Stock. Oh well - that's racing. Next event is in Michigan in two weeks. Anyways, I had the 99, not the new 04. NJ is a bit far to come just to run test-n-tune.
you did say reference didnt you?
that was a GMHTP/MM&FF combined test?(12.8 pass?)
too bad it wasnt you.wouldve had to take care of business.
GMHTP and MM7FF are the same folks, so I'm sure they crossed the data over. And I heard Sean already took care of ya, so I ain't too worried.
Originally Posted by Bob Cosby
No way! Is that the secret? Don't let it out! Gear is for wimps! And it sucks on the highway! Viva la Gas mileage!
Oops...they probably don't want to go there either.
Prove it. Post a link. Post a scan. Post something that can actually be backed up with facts (a first, I'm sure).
Correct - and I still stand by my conclusions. Further, using "best ever" stock ET's shows the potential of the cars. That potential is a good indicator of how far off the two will be with the "average" driver - assuming both take about the same skill to drive.
You have no clue how long they last. Then again, a clutch is a maintenance item....if you understand what that term means.
My bone stock 99 Cobra times sucked - all 2 times I had it at the track.
You can only wish I was drunk.
"Ya Mom, I had the cash to buy this brand new 500 HP $80,000 Viper, but I really like used $10,000 Mustang GTs better, so I took out a loan and picked one up."
BTW...where did I ever mention anything in this post about class racing? Steve Y would be wise to leave his "guns" in the mud where he first planted them. Right now their basically shooting blanks into the ground.
steve, sorry to say this, but you have some issues....
i would recommend you getting rid of that gt, and buying an lt1, or better yet a low 13's stock ls1 fbody.
bob is giving you all the facts, and you are just sounding like a typical honda civic type r owner.
i can go cruising the streets at 50mph in 5th gear. i'm cruising, i'm not towing a trailer, why would i need all the lt1 tq below 3000 rpms, if you're racing, you don't want all the torque below 3000rpms. if you're cruising, what difference does it makes if you have tq below 3000 or not, that you have more tq to speed up from a 50mph roll in 5th gear???,
too bad a 350z would smoke your lt1, and a 350z is not even putting half of an lt1 tq below 3000 rpms. (stock vs stock), i know about h/c lt1's ok!!!
http://www.edmunds.com/used/2001/for...denav..6.Ford*
I have a question for you Bob. According to the above link your car weighs about 3430 lbs. The link was for a 2001 car, they didn't have a weight listed for the '99 car which is very similar to yours from the factory. So your car with a full tank of gas, spare, jack etc. weighs 3430 right? On your website you say that you lost 305 lbs. from weight reduction. But your car weighs 3335 lbs. with you in it on race day. So 3430-305=3125. Don't you run the car with nearly an empty tank of gas? That would be another 70ish pounds. Don't you run the car w/o spare, jack, extra seats, etc? That would be another 80ish pounds. So you weigh 210 lbs. + 70 + 80 lbs. right? Sounds like you, not the car needs a diet!
Low end torque is fun and great for a daily driver. What 350z would smoke my LT1? I don't own an LT1. Yes, i'm sure the 350z puts out more than 1/2 the torque of an LT1 below 3000 rpm. You don't know your a** from a hole in the ground and you are dissing me?
Originally Posted by Steve Y
Yes, let's go there. Gears cause higher rpms on the highway which eats up more gas, makes more noise and vibration and decreases longevity of the engine. Let me guess you get better mileage on the highway with your 4.56s than with your stock 3.27s?
I read it in GMHTP. It was their '93 yellow project car. I am not going to waste my time doing a search for it on the web. Read the old mags if you don't believe me.
Prove me wrong, or prove to everybody what you are - an internet racer.
Assumption is the mother of all f. ups. Average is not necessarily the same as best times. From what I have seen, it's about 4 tenths and 4 mph at my dragstrip. How would you know what I saw? Were you there? No.
To answer your question, no, I wasn't. Would you like a list of tracks that I've been to since the LT1 debuted in 1993, and then should I ask you if YOU had been there? How about just this year? Bueller?
Ok, how long do your clutches last?
However, I went in excess of 30,000 miles on the original (before toasting my first T45 in the summer of 2001). I've never changed a clutch because it was worn. Rather, it makes sense to change it whenever the tranny is out for breakage. Have fun with that one.
See, you suck at slipping the clutch with street tires, that was my point.
Your that much of a moron, sober? Scary!
You have no idea about my financial situation. Believe what you want. I'm not going to post stock certificates and the title to my house on the web for all to see.
That was pretty funny. I got to give you credit for a change.
Once again....line item style...lets do some disecting...then I've GOT to get off my butt and go mow the backyard.
Anyways, I never weighed my car empty. I did, however, weigh it at the track, with me in it, spare/jack, but very little gas. It was 3590 lbs in that state, so ya, 3430 is probably about right.
So 3430-305=3125.
Here are some facts you either couldn't know or didn't bother to research before trying to make such a dumb statement.
The 305 lb referenced above included a tubular K-member, which is illegal in the class I race in, and did not include the 6 pt moly rollbar that is now in the car. Installing the stock K-member back into the car adds 55 lbs. The rollbar adds back ~50 lbs more.
Oops #1.
My race class has a minimum weight of 3325 lbs. A smart racer always leaves a little bit of cushion, so I try to run with the car around 3340 lbs. To do this requires me to add ballast (you know what that is, I assume?). My ballast consists of an iron bar filled with lead. It weighs 75 lbs and is legally bolted in my trunk (and is very easily removed). I also sometimes carry my spare and jack, as all scales vary a little, and if I need the extra weight, that's a convenient way to legally add it (by legal, I am referring to tech inspection).
Oops #2.
And finally, to disappoint you completely, I do not weigh anywhere near 360 lbs. In fact, though I'm hardly skinny or thin, I come in at about half that, and even do an occasional bit of running....such as the Bay Bridge Marathon back in 2002 (that's 26.2 miles, BTW).
The final oops...for this time, anyways.
While Bob is being a total dick, so is everyone else in this thread.
The problem is, he's totally raping all you guys with good old fashioned experience and know-how. Sure the LT1 has good low end grunt, but as Bob has mentioned the regular driver is only under 3k once during a race; and actual racers are never under 3k.
Has he said that the LT1 doesn't have its own merits and is not fun to drive? Not even close. He merely stated that the LS1 will tear it a proverbial new one in any legitimate speed comparison.
You guys are even so heated from this argument that you've begun slamming the LS1's that you all undoubtedly look up to, just trying to scrape for something to prove Bob wrong with. He obviously can drive. He obviously knows his stuff. And if he's being a cocky ****, perhaps its because he and his car can back it up. Numbers don't lie and Cosby's got them in spades.
Let's just agree to disagree that each car has it's own merits, people are entitled to their own opinions, 0-3000rpm races don't matter, and horsepower is indeed a derivative function of torque---the latter of which not being the only thing necessary to win a drag race.
Keep the American V8's cooking, guys, and I have no problem with whatever company flag you're flying as long as you love your car and respect others.
I'll take your recommendations to heart, really.
