Sticking brakes, need help
Old Apr 28, 2021 | 08:38 PM
Homemechanic's Avatar
Okay so I've got a weird problem and I'm hoping you guys can help.
I drive a 96 z28 and three weeks ago I noticed a grinding sound from my rear discs. So I changed the pads and went for a couple block test drive and when I pulled back into my driveway both rear brakes were smoking. The old pads had been very unevenly worn so I figured the calipers were bad. So I replaced both calipers and went around the neighborhood again. Still smoking. I looked on here and found out that I had most likely pinched the lines.
Now I have just finished replacing the rubber lines with braided ones and I still cant turn the wheels with the car in neutral.... I'm at a loss as to what the problem is.
any ideas would be appreciated
Old Apr 28, 2021 | 09:21 PM
Re: Sticking brakes, need help
Any chance the e-brake cable is hung up and not releasing?
Did the calipers come with new guide pins, or did you reuse the old ones?
Old Apr 28, 2021 | 10:29 PM
I currently have the park brake cables disconnected.
And the new calipers came with new brackets and pins..
RKPsk8er
Feb 15, 2007 03:06 PM
seanmpope
Dec 30, 2006 01:14 PM
5H9D0W
10
Jul 29, 2005 09:25 AM
cndctrdj
Sep 10, 2004 03:47 AM
vancity69
V6 Tech
Jan 23, 2004 03:28 PM
