BMR Manual Brake Master Cylinder
Old Jun 28, 2021 | 11:17 AM
DrewHMS97SS's Avatar
I just purchased a BMR manual brake master cylinder to help make room for the Vortech after cooler. The master cylinder is from Strange, and specifically indicates that the rear port on the master flows more fluid, and should be connected to the front set of calipers for anything other than drag racing.
Is the stock master cylinder the same setup? Can anyone verify which port on the ABS pump is for the front brakes?
Old Jun 28, 2021 | 02:18 PM
Re: BMR Manual Brake Master Cylinder
If you have the 96 factory service manual (should be identical to 1997), the pipes from the master to the combination valve are shown on page 5-11.
On the master, rear port (toward firewall))is for front brakes, front port is for rear brakes.
On combination valve, front brake line connects to front port, rear brake line connects to rear port.
Old Jun 28, 2021 | 06:24 PM
Thanks Fred, I do, and didnt even think to look there
malibudave
10
Jun 28, 2017 01:07 PM
wrd1972
Mar 17, 2007 08:34 AM
firebirdjosh
Sep 18, 2005 11:24 AM
slp223
Feb 10, 2004 05:44 PM
BlackDog
Mar 2, 2003 10:57 AM
