NX system doesn't work, schematic inside
Old Aug 26, 2004 | 10:58 PM
  #16
DrewHMS97SS's Avatar
Re: NX system doesn't work, schematic inside
Originally Posted by 94NDTA
It is set at 35 psi. How do you test it?
take a multi meter and check the connection. cap one side of the manifold and take a blower w/ a pressure regulator on it. blow into the otherside of the manifold and turn down the pressure until the connection is broken. reset and retest as required.
Old Aug 27, 2004 | 02:40 PM
  #17
94NDTA's Avatar
EDIT: I am the biggest dumbass on the site.
I forgot to remove the schrader valve in the test port. I remembered it needed to be done, I just thought I pulled it allready. Sorry for wasting your time....thanks for all the help....I'm going to go have some fun now.
Old Aug 28, 2004 | 10:06 AM
  #18
12SCNDZ's Avatar
LOL...You know most people wouldn't have admitted that I'm sure you're not the first to do it, though.
Look at the bright side...There's already a long running thread on here titled "What's your dumbest mistake"...Now you can add to that thread
If that's your worst mistake, you're lucky...Try having a harmonic balancer fly off at 6200 RPM's
Frank
Old Aug 28, 2004 | 10:36 AM
  #19
Frank
OUCH!
Old Aug 28, 2004 | 11:02 AM
  #20
94NDTA's Avatar
I thought about not posting it, but then I figured it wasn't too bad of a mistake because the nitrous can't really hurt my system if the fuel isn't on, completing the ground. Oh well, ya live and ya learn.
Old Aug 28, 2004 | 11:20 AM
  #21
ill trade ya, the guy who built my motor shimmed a high volume oil pump to 80psi. it blows filters, so now im trying to figure a good way to pull the pan
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Evilfrog
Aug 7, 2002 11:36 PM
Brian-94TA
Jul 31, 2002 02:52 PM
Snake Slayer
Jul 26, 2002 06:14 AM
