Fpss????
Fpss????
Just wondering if this FPSS will work for me. My car is a fuel injected H/C car. If this one won't work then which FPSS will work for me. Thanks
http://www.jegs.com/i/NOS/741/15750/10002/-1
That one is for a low pressure fuel system...it has a preset 5psi shutoff. The LT1 runs approx. 45psi fuel pressure, and needs a higher shut of capability.
http://www.nitrousoutlet.com/catalog...roduct_id=2553
this one includes the fitting you will need to connect to your fuel system.
You have to order the correct pressure, NOS offers both low and high pressure adjustable switches:
Everyone uses the same pressure switch, made by Honeywell/Hobbs (although some outfit with "Pro..... " in their name is probably having rip-offs made in China by now):
http://content.honeywell.com/sensing...scorp/P3_6.pdf
Adjustable Fuel Pressure Safety Switches
Control your car's fuel pressure and avoid the risk of shooting nitrous with too little pressure to supply the extra fuel required. These heavy-duty switches are offered at 5, 7, 15, 30, or 50 psi.
Ok, just getting my kit installed and wanted to make sure before I spent money on a part that wouldn't screw into my existing fuel solenoid. Trying to make it look as clean as possible under my hood.
FPSS are not brand specific....the difference between manufacturers is the fittings they use to attch the FPSS to the system. We use a manifold with multiple accessory ports. THis gives you a plce to put the FPSS and another item such as a fuel pressure gauge, without having to buy more fittings.
