What Window Switch and FPSS for a ZEX Dry kit?
Old May 6, 2004 | 09:41 PM
Kris96WS6's Avatar
I have a LT1 ZEX Dry kit coming and I would like to get some of the other safety items (window switch and fuel pressure safety switch) Since these are not available from Zex has anyone else found other brands to use and gotten them working? I would like to have the fpss read the pressure after the regulator. I plan to have the car tested on a dyno with A/F readings and FP after regulator will be noted. The FP corresponding to correct A/F readings will be noted and I would like to be able to set the FPSS to "signal cutoff" if the FP drops a few #’s below this number this way I am not only protected from a fuel pump failure but also from a regulator (or vacuum to regulator) failure. What do you folks think?
Kris
Old May 8, 2004 | 11:14 PM
BILLJ's Avatar
You got mail!
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
