N.O.S. fpss??
Old May 6, 2003 | 02:01 PM
snksknr94's Avatar
N.O.S. fpss??
I just need to get a fpss so I can start my install. I made a post here a while ago about what fpss switch to get. Somebody gave me the N.O.S. pn of 15750, but that switch is only for 7-10 psi. Don't I want the kit to shut down if the fuel pressure starts to drop at a much higher psi? Does N.O.S. make a fpss switch better suited for higher fuel pressures of fuel injected cars? I see a lot of people mentioning NX fpss, but I'm ordering from Summit and they don't carry NX yet. Any help would be great, I wanna place my order today, so I can hopefully start my install this weekend. Thanks!
Old May 6, 2003 | 02:19 PM
NOS PN 15685 is a "50psi" Hobbs fuel pressure switch. It can be set to pressures higher than 50psi.
Old May 6, 2003 | 02:21 PM
snksknr94's Avatar
And that one will shut off the kit if the pressure starts to drop?
Old May 6, 2003 | 02:34 PM
Yes... it can contacts that can be wired up to open or close, as I recall. I used one with the NOS 5176 kit. Set it so contacts close over the desired pressure, open below the desired pressure.
craigffb
N2O Tech
Aug 24, 2003 12:21 PM
snksknr94
N2O Tech
May 7, 2003 01:04 PM
Hawk
N2O Tech
Mar 30, 2003 10:48 AM
RMC
Mar 3, 2003 04:26 PM
stockLT1
N2O Tech
18
Aug 3, 2002 10:03 AM
