Who has seen 918 beehive springs do this?
Old Jun 8, 2007 | 01:00 AM
  #31
11sec_z06's Avatar
Originally Posted by Z28LT1_Just_Nasty
The question in my mind now is, what springs to use now? I'm beginning to plan out my valve train for a cam swap and the 918's were going to be the springs to use. I just don't want to run any risks, I keep seeing these break.
PATRIOT PRC GOLDS (DUAL) $255
CRANE 832 (DUAL)
COMP 921 (DUAL)
Crane 144832
O.D. outer: 1.275
O.D. inner: 0.937
I.D. inner: 0.667
112 lbs @ 1.800
352 lbs @ 1.150
coil bind: 1.045
MAX LIFT 0.650
spring rate: 352 lb/in
Comp 921's
O.D: 1.300
I.D: .870 (outer spring)
I.D: .655 (inner spring)
135 LBS @ 1.770
400 LBS @ 1.220
COIL BIND @ 1.040
MAX LIFT .650
rate: 408 lb/in
PATRIOT PRC golds
O.D 1.29
135lbs @ 1.800
385lbs open
coil bind @ 1.08
.650 lift
Old Jun 8, 2007 | 01:02 AM
  #32
11sec_z06's Avatar
Originally Posted by speed_demon24
Does anyone have the batch #'s on these springs? I bought mine december 06 and want to see if I have the same batch as the ones that are breaking.
Old Jun 8, 2007 | 01:18 AM
  #33
sbs's Avatar
sbs
I asked Lloyd Elliot about this a couple months ago and he said he switched to PAC Beehives a while back. PAC was the previous manufacturer of the 918s. The problems with the 918 seem to have started after the change of suppliers.
Old Jun 8, 2007 | 06:32 AM
  #34
wrd1972's Avatar
Lloyd hooked me up with the PAC springs rather than the CC's. I actually recivied replacements from CC but I sent them back.
The PAC springs looked better on the tops and bottoms where they are machined flat. They were very smooth where the CC's looked rough and course.
Old Jun 8, 2007 | 08:44 PM
  #35
94ZRiCeKiLr's Avatar
I'd like to add my story to this thread.....
BATCH # 49253 produced this after 2000 miles with no track passes, no over-revs and NO high-rpm operation before operating temperature.
In addition to this, I also know that someone reported a failure from BATCH # 49045.
While I don't know everyone's batch number, THREE people, just that I know personally have reported failures, as well as SEVERAL more that I don't know.
Engine damage has varied based on whether or not someone was lucky enough to have the broken coil stay seated under the retainer so the valve couldn't drop. I myself was lucky enough to pull this spring out before it did any damage.
Old Jun 8, 2007 | 08:51 PM
  #36
These were removed from a '98 LS1 belonging to a friend of mine after 1000 miles.
I don't have his batch number yet, but I will get it from him if he's got it and add it to this post.
Old Jun 9, 2007 | 02:33 AM
  #37
rasputin's Avatar
And this would be a picture of one of my broken 918's (two broke), causing the valve to drop and destroy my piston, thus destroying my motor. This is on the setup listed in my sig.
Ordered July/August 06, not installed till January and ran till about 1500 miles and broke at 1600rpm going 20 miles an hour. Blah.
Old Jun 9, 2007 | 05:41 AM
  #38
rskrause's Avatar
Moderator
I am thinking this is a design flaw, not a manufacturing problem. Else why would all the breaking be right at the top coil?
Rich
Old Jun 9, 2007 | 02:10 PM
  #39
you wouldn't happen to know your batch number would you? I'm actually compiling a list on some of the other forums. I can transfer it over here too if there's any interest.
Old Jun 9, 2007 | 02:11 PM
  #40
Rich
Well some people are suggesting that the spring's inherent weakpoint is right where it flattens to form the retainer seat there, thus contaminated (ie: weakened) steel would be most likely to break there....
Me personally.....I haven't got a clue exactly why it's happening. I just know something has got to be wrong here.
Old Jun 9, 2007 | 03:34 PM
  #41
plattted's Avatar
springs
Too bad, we as aftermarket purchasers of parts are constantly being assured that the items we buy are the greatest, the best. Cams, then lifters and now springs. Marginal, at best equiptment,is being advertised here. We need a lot more! Meanwile we continue to support these vendors with our hard earned and hard to save dollars, only to find that there was a small batch of failures that lead to catastrophic failure of of our prised auto.
These vendors should be made to compensate us for our/THIER mistakes. Not just say, we will send you new springs! Another ripoff!!!
Old Jun 9, 2007 | 04:55 PM
  #42
mpe331lx's Avatar
Subscribing
Old Jun 9, 2007 | 06:21 PM
  #43
Kevin Blown 95 TA's Avatar
I always dress my springs top and bottom, but now I'm worried about them after reading all of this. I did measure all the springs and compress them on a press to look at the pressures - wonder if any of that helped. Sure seems like a defective part to me. Makes me want to pull my valve covers off tomorrow and just look at them... Little over 2k miles & quite a few high speed blasts - lift is 235/255 at the spring.
Old Jun 9, 2007 | 06:25 PM
  #44
rasputin's Avatar
responded on other thread
Old Jun 9, 2007 | 09:48 PM
  #45
Joseph Overton's Avatar
Spring with dampener, such a simple concept....LOL
