What should I do next?
Old Mar 10, 2012 | 09:30 PM
  #76
Cerridius's Avatar
Re: What should I do next?
Changed the fuel pump. Pressure is where it should be
Old Mar 11, 2012 | 09:23 AM
  #77
mrmint69's Avatar
It sounds just like my car and I have the stock cam.
Old Mar 11, 2012 | 09:55 AM
  #78
Cerridius's Avatar
Ya I'm pretty sure I don't have a camshaft. But I guess that will be my next step in the future.
Old Mar 11, 2012 | 04:01 PM
  #79
lt1-xjs's Avatar
Originally Posted by Cerridius
[autostream]http://autostream.com/camaroz28/?page_type=firebirdplayerthumbnail&framepage=2577& transactionid=1331170119-70129128166&posted_by=Cerridius_www.camaroz28.com& youtube_video_id=sHgvVgP7hbQ[/autostream]
Here's the idle. drag race was put off till next Thursday. Maybe I'll get my pump, stall and regulator in.
The link doesn't work for me.
Old Mar 20, 2012 | 08:40 PM
  #80
Cerridius's Avatar
Put the torque converter in today. Yank ss3600. Feels pretty good. Not as loose as I thought it would be so that's a good thing. Only thing is it feels like my shift kit is gone because it shifts to second real smooth. I guess that's just because of the converter. I'm sure I'll feel it again when i go WOT gotta break it in 150 miles.
Old Mar 22, 2012 | 06:19 PM
  #81
Cerridius's Avatar
I don't feal a big difference with the torque converter at all. I feel like I got the negatives more than the positive. I mean I can brake hold it more and it will shred the tires but it's not like I thought it would be. Yank ss3600
Old Mar 22, 2012 | 07:49 PM
  #82
lt1-xjs's Avatar
My Yank pulled 5 tenths off my 1/4 et.
Old Mar 22, 2012 | 11:14 PM
  #83
Cerridius's Avatar
Ya I'll see what it does for me at the dragstrip. I'm sure my butt meter can't feel a half second difference.
Old Mar 23, 2012 | 02:21 AM
  #84
Fatdog2's Avatar
Might try NGK TR55 spark plugs.Might change the cat.My02(Check the coil,and the coil wire)Hope this helps.
Old Mar 23, 2012 | 04:14 PM
  #85
Cerridius's Avatar
I just changed the spark plugs, there autolite. Im thinking about changing the cat, maybe buying a highflow or removing it completely but I dont want to throw a code. I think I changed my coil already. But I did not change the coil wire because It had a nice blue 8mm wire on it while I used stock wires on my sparkplugs.
I want to delete the cat, I dont care about passing emmisions, law and whatever. I just dont want my computer to throw a code.
Old Mar 23, 2012 | 08:40 PM
  #86
Your 94 does not set a code if you remove the catalytic converter. There is no after-cat O2 sensor in an OBD-I car. Unless your cat if plugged, removing it isn't going to accomplish much in the way of power gains.
Old Mar 23, 2012 | 09:20 PM
  #87
Cerridius's Avatar
Any way to tell if it's plugged by looking inside of it? I plan to take it off.
Old Mar 24, 2012 | 01:22 AM
  #88
You check for a plugged cat by measuring the pressure in the exhaust system. Any decent exhaust shop should be able to do that for you. But if you are taking it off, what difference does it make?
Old Mar 24, 2012 | 07:57 AM
  #89
Cerridius's Avatar
Just out of curiosity that's all.
I'm about to buy some stock heads today to use them for porting.
Old Mar 24, 2012 | 09:15 AM
  #90
Which castings are they - 643 or 561?
The photos are gone, but read this:
https://www.camaroz28.com/forums/lt1...inside-427346/
