What should I do next?
Re: What should I do next?
Valves are here, Does anyone know where I can buy 1 retainer for my crane 10308-1 kit if summit dosent get the manufacturer to send me one? Need my retainer so I can send my heads down! Still looking for a cam and rockers.
Ok heres my plan. Cc503 cam for sure. I plan to buy some scorpion SA 3/8 rockers.
Do I need hardend pushrods still even with no guideplates and SA rockers? Anyone know what length pushrod with ls7 lifters? Or should I just get a measuring tool. Or are my stock rods fine.
Also, my engine only has 100k miles. Maybe i can get away with my stock lifters and pushrods?
I went to the track and got a new time.
Old 60ft 2.36. New 2.149
Old 330ft 6.5 New 6.174
Old 1/8 9.85 New 9.46
Old MPH 74.58 New 73.64
So I guess the torque converter did something maybe. I did decrease my tire psi to 25lbs though.
Things that changed since the old track times. Torque converter cutout fuel pump and FPR
9.46 x 1.555 equals 14.71. I had a bone stock 95 formula automatic that ran
14.10 at 98 mph at Atlanta dragway. I put a Borla 2 3/4" y pipe on minus the cat and went 13.94 at 100.5 mph. This car had the factory 3.23 gears. If not mistakened its been a few years I ran 79 mph in the 1/8 and 8.9 sec.
This car also dynoed 281 rwhp with the borla y pipe.
Maybe you need to have it dynoed tuned. You should be in the 13's easy with your mods.
It's cool haha, idk what's wrong lol the car feels fine but I guess it's
Not. Maybe the PCM tune it got made it worse. I plan to get a dyno tune after my head/cam swap
You need to data log the car.
[autostream]http://autostream.com/camaroz28/?page_type=firebirdplayerthumbnail&framepage=2603& transactionid=1333412885-668798233&posted_by=Cerridius_www.camaroz28.com&yo utube_video_id=I_ZHApWF6Rg[/autostream]
I don't think I spun the tires at all.. My car is just dumb gawd... I'll get a dyno tune when I swap my heads and cam. I'm gonna run my GFs stock 94z28 in the 1/8 and see how hers performs.
My car's SES light is starting to come on while I cruise at about 35-45mph and will turn off maybe 3 mins later. Its done it on 3 drives so far, seems like only when im cruising. I took a spark plug out and the tip is white. Im thinking about buying a scanning cable and using a laptop to scan it. What program would I use?
Still sounds like your down on power for your combo, Injuneer give you some good advice. Before I did any mods I would invest in a good code scanner that will data log and read real time. For instance, what if the knock sensor is picking up false knock and killing your timing , If you can't data log or read real time you hav no way of knowing (it would'nt throw a code and will kill your times). Just a thought!
As for the timing and knock mentioned before, that is a serious possibility. My car was pulling knock recently and made it very sluggish. Consider using freescan to see what the knock and degree of timing retard is. Anything over 1* is probably a bad thing, I was pulling around 10~12* and it was horrible.
My car bone stock ran a best of 14.02 at 99 mph.
