What should I do next?
Old Mar 27, 2012 | 01:14 PM
  #106
RamAir95TA's Avatar
Re: What should I do next?
Well I hope you have good luck with them. My opinion does not change. It's just NOT worth the risk.
Old Mar 27, 2012 | 03:23 PM
  #107
lt1-xjs's Avatar
Originally Posted by Cerridius
Just bought the Elgin 2.02 valves and 1.6 exhaust. And the crane 10308-1 spring kit. Now I think all I need is the cc503 camshaft. Pushrods. Lifters (maybe engine only has 100k). 1.6 roller rockers. Maybe a timing chain.
You may also need new valve seats to install those valves. I think the stock seats are limited to 2.00" and 1.56" sizes.
Old Mar 27, 2012 | 04:29 PM
  #108
2QUIK6's Avatar
The only local person that knows how to port lt1 heads is Lloyd and since you said he is taking them to Houston I know your gf's cousin isn't Lloyd.
With 8 pages of advice and guessing why or why not it was not putting down power no one suggested getting a scan tool. The most valuable tool one could have to diagnose an efi engine, especially with all the mods you're getting into. A simple o2 being lazy can have you running in circles for months. A problem injector would be much easier to diagnose.
Old Mar 27, 2012 | 04:58 PM
  #109
Originally Posted by Injuneer
But even simpler is to scan it for codes. If there is a fault in the injector circuits - no volts, wrong ohms or no ground, the PCM sets a code. Have you had it scanned?
Originally Posted by 2QUIK6
With 8 pages of advice and guessing why or why not it was not putting down power no one suggested getting a scan tool. .
au contraire
Old Mar 27, 2012 | 05:24 PM
  #110
2QUIK6's Avatar
If there are codes the SES light will be on and a paper clip can tell you the code. How about DataMaster or some other scan tool to give you the sensor readings. There will be no SES light for a lazy o2 and many other scenarios.
Old Mar 27, 2012 | 06:28 PM
  #111
Dave89IROC's Avatar
Not all codes trip the ses, and IIRC, the paperclip doesn't work on 94/95 cars
Old Mar 27, 2012 | 07:06 PM
  #112
2QUIK6's Avatar
ok never mind, take it to auto zone and they will tell ya all you need to know
Old Mar 27, 2012 | 07:33 PM
  #113
Autozone often reads only OBD-II computers.
Old Mar 27, 2012 | 10:22 PM
  #114
Cerridius's Avatar
Ya autozone and o'reilly can't test my car. Where are the O2 sensors at anyway. I don't even see them. Also my catalytic converter I found out was completely empty. So it's basically like I had a straight pipe but it was made to look like I had a converter.
Old Mar 27, 2012 | 10:26 PM
  #115
Cerridius's Avatar
The person doin my heads said he will supply the valve seats
Old Mar 27, 2012 | 11:08 PM
  #116
Cerridius's Avatar
Btw my porter has done plenty of lt1 heads and ls1 heads and BBC
heads and other heads. The only reason everybody likes Lloyd
heads so much is because how popular he is because he specially caters to the lt1/ls1 crowd.
Old Mar 28, 2012 | 03:17 AM
  #117
Cerridius's Avatar
Quick questions. Are my head bolts reusable? And with 1.6 rockers should i use NSA or SA.
Old Mar 28, 2012 | 09:16 AM
  #118
sandman2100's Avatar
Yes, if they work now, all you'll need to do is refresh them. Seals, Spring check, surfacing.
I'd go NSA, on 7/16 studs. SA limits your spring and lift choices.
Old Mar 28, 2012 | 09:50 AM
  #119
RamAir95TA's Avatar
Does your LT1 head porter have any proven and documented results for his efforts?
Old Mar 28, 2012 | 10:43 AM
  #120
Cerridius's Avatar
What do you think about self aligning rockers with my crane 10308-1 spring kit (got them in today btw and its missing 1 retainer) and a cc503 cam
