trouble starting
Old Aug 24, 2010 | 08:21 PM
swtbtyctrygirl's Avatar
trouble starting
I have a 95 z28 that turns over but wont start. we redone the head gaskets, and the intake gaskets. replaced the optispark. My husband sprayed it with starting fluid and it cranked, then we finished putting all of it back together and now its not. There is plenty of gas going to the injectors. Someone help I bought this car after waiting 7yrs to have another one, drove it home and havnt gotten to drive it since.
Old Aug 24, 2010 | 08:28 PM
RamAir95TA's Avatar
Check to see if the coil is firing. If it is, check to see if you have spark coming out of the optispark. If both of those look good, next suspect the fuel system for inadequate pressure. You can check fuel pressure using a fuel pressure test gauge available at pretty much every parts store.
If you aren't getting any spark out of the coil, you can follow this diagnostic to help track down the issue:
http://shbox.com/1/4th_gen_tech2.html#opti_test
Good luck!
Old Aug 24, 2010 | 09:50 PM
Have you checked the PCM for codes?
Old Aug 25, 2010 | 02:21 PM
all the fuel pressure is reading normal. he sprayed starter fluid in the throttle body and it started but died quickly. We did check the codes and it showed open circuit, but none of the wires are cut or broken, checked all fusable links and fuses, he says its acting like there is not fire. we replaced the coil module, and the opti spark.
Old Aug 25, 2010 | 02:30 PM
razor02097's Avatar
What PSI was the fuel pressure reading?
How about the security light? Is it on?
Old Aug 25, 2010 | 02:42 PM
GRIDERMAN87's Avatar
Its not sounding spark related if it fired and then died...pressure should be 40#
Old Aug 25, 2010 | 03:05 PM
security light is on when you turn the switch on. before when it was running it was not though, and the pressure reading was 40. I have noticed that the engine tempature cooling sensor plug is broken would that cause it to do this, you can still plug it up but im not sure if that is whats causing it not to crank.
Old Aug 25, 2010 | 03:07 PM
does the light flash or just come on and the go back off after the key has been on, the temp sensor wouldnt cause it not to start
Old Aug 25, 2010 | 03:15 PM
it comes on then goes off after just a minute, no flashing though. you guys rock thanks so much for helping me.
Old Aug 25, 2010 | 03:24 PM
It isnt sounding like its the VATS either, to be clear did the car run with starting fluid, or did it just "bust off" or try to start?
Old Aug 25, 2010 | 03:32 PM
it ran with the starting fluid, thats why i am wondering if it could be my throttle body?
Old Aug 25, 2010 | 03:47 PM
sounds like its fuel related somewhere, connections to the Mass Air, and injectors, could be a lot of things these are just guesses from your symptoms
DirtyDaveW
Dec 1, 2016 05:37 PM
armedtrigger
Feb 24, 2015 08:30 PM
warmeck
Feb 2, 2015 12:44 AM
David Dorris
Jan 17, 2015 08:10 PM
slothgrant
Aug 22, 2002 03:01 PM
