Water pump bolts, reuse or replace? Part #?
Really unnecessary. Waterpumps are not stressed parts like a head bolt, cam bolt, reciprocating assembly fasteners, etc. that can wear out or fail after repeated torquing. Unless the bolts are damaged or you are changing them for asthetics, i would leave them alone and save your money.
I've replaced my waterpump/opti 4 times now and reused the same bolts...however I've always cleaned the bolts and bolt holes with degreaser and brush. Seems fine to me. No need to waste money, unless you see something wrong with the bolts.
The bolts are just gunked up with crap. If I can't get them cleaned up then I'll just replace them.
