remember horrible dyno numbers well got leak down take a look!
Old Feb 10, 2005 | 02:01 PM
red96z's Avatar
ha ha ha less than 6% acroos the hole motor so not a tired motor!mechanic impressed right at 100k miles!so what else is robbing me of power.cam not degreed in right?slipping converter trans?bad tune?btw machanic said that belt was halfway falling off the crank pulley and almost cut through a wire on he front pass. side????
Old Feb 10, 2005 | 03:01 PM
1quikZ's Avatar
Re: remember horrible dyno numbers well got leak down take a look!
At this point your guess is as good as mine, Everthing i would suggest you have already done. Must be the cam..................
Old Feb 10, 2005 | 03:42 PM
xxsaint69x's Avatar
hmm why dont u try replacing the cut wire
Old Feb 10, 2005 | 04:40 PM
red96z's Avatar
We did replace the cut wire and the belt. I don't no how long the wire has been like this. I think the guy at the dyno my have done this when he was getting the clamp on #2 plug wire.
Old Feb 10, 2005 | 04:45 PM
SSmoked's Avatar
Welcome to my world. I found out that my belt was half way off the crank pulley so i replaced it. Afew days later it shredded in half. So now im driving around with a belt thats half the width. How old is your belt tentioner?
Old Feb 10, 2005 | 04:47 PM
red96z's Avatar
Could the cam still be a tooth off with no leaks?
Old Feb 10, 2005 | 08:41 PM
red96z's Avatar
i cant believe no input!is everyone stumped i know i am.im going back to the dyno tomorrow just to see if it was the wire im going to make a run as is then if i have the same result, im going to switch the pcms back to the obd2 thats all ready programed for my car i still have it luckly cause i have not sent it back to bryan at pcmforless.the pcm in my car now is the obd1 conversion from bryan.anyways hope that works but just dont know.if not im really stumped.there has to be one of you guys that has some suggestions for me to look into.HELP!
Old Feb 10, 2005 | 08:58 PM
med_reject's Avatar
u didnt get a cc306
Old Feb 10, 2005 | 09:13 PM
red96z's Avatar
Originally Posted by med_reject
u didnt get a cc306
i got the box to it.and reciept from comp u cant be serious,well i guess its possible!everythings possible.
Old Feb 10, 2005 | 11:00 PM
Eff's Avatar
Eff
Talking Re: remember horrible dyno numbers well got leak down take a look!
If you got a dial caliper with a long enough needle, you could proabably check the duration off one of the lifters.
Maybe the dyno just didn't like your camaro.
Old Feb 11, 2005 | 10:48 PM
med_reject's Avatar
maybe the timing is not aggressive enough, but that should only be a few HP. I guess we need to think of all the possible causes of HP robbing, including inaccurate dyno!
Old Feb 12, 2005 | 12:48 AM
i cant believe no input!is everyone stumped .....
I think the problem is you started a new thread to give the results of the leakdown test. You could have put this info as a post on the original thread, so people could refer to the dyno results you probably posted there, and see what others have previously identified as the possible problem. Now there is no way for anyone to know the details of your original problem, unless they do a "search" and try and find your original post. Most people will not take the time. That's why its a good idea to keep the entire problem in a single thread.
rideordie
Nov 5, 2019 04:52 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
ChrisFrez
Feb 22, 2015 08:47 AM
Joe Brodman
Jul 24, 2002 05:24 AM
