Quick crank pulley question
Old Jul 29, 2004 | 10:34 AM
Loadre's Avatar
Does it matter which way the crank pulley goes back on? Will it effect the balance of the motor or anything?
Old Jul 29, 2004 | 10:40 AM
QUASARBLUEZ28's Avatar
Re: Quick crank pulley question
I would think its neutral balanced so it would not matter. I have always marked mine when I remove it, from some old habits.
Old Jul 29, 2004 | 10:42 AM
Loadre's Avatar
I would think it is neutral as well I just need to make sure. Was doing something else on the car and I figured my dad could handle putting it back on, even when I told him which way it should go. Turns out he turned it wrong.
Old Jul 29, 2004 | 10:45 AM
Are you bolting the damper/pulley back on the hub - 3 bolts? If so, the bolts are not equally spaced. It will only go on one way.
Or, are you mounting the hub back on the crankshaft?
While it is neutral balanced, at times some minor balance "trim" is done using the damper/pulley.... nothing major, but it would be a good practice to put it back pretty much where it was assembled by the factory if reinstalling the hub..
Old Jul 29, 2004 | 01:38 PM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
slightly off topic. i was thinking of going with some tpis underdrive stuff. can i do this with the normal tools or do i have to get something special?? thanks.
Old Jul 29, 2004 | 01:43 PM
In theory the damper/pulley comes off the hub simply by loosening the three bolts.... mine did when the car was only a few months old, but after several years of rust, they sometimes require a 3-jaw puller to get them off. Shoebox has the setup covered on his website.
Old Jul 29, 2004 | 01:44 PM
Loadre's Avatar
Ah, good to know. Maybe my memory just failed me on which direction the arrow was pointing.
HectorM52
Jun 23, 2016 08:42 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
CARGASM
Sep 4, 2002 11:17 AM
