New LE2 355 Running Rough.
Old Apr 1, 2009 | 10:14 AM
  #61
Nostang 96z's Avatar
A quick check is to take one spark plug out of the head and stick your thumb over the hole (unplug the injectors or fuel pump relay) while someone cranks the engine over. If you feel a lot of air then you have good compression and the valve train is working properly. If not then it is most likely a pushrod issue.
Old Apr 1, 2009 | 10:15 AM
  #62
PS---don't worry about hooking up the water pump and all that other front accessory stuff until you get it figured out. The engine can start and run for a few seconds without that stuff and not hurt anything.
Old Apr 1, 2009 | 11:46 AM
  #63
wrd1972's Avatar
Good point. I ran mine for about 23 seconds, without a water pump with no ill effects.
LeftoverChinese
Jan 14, 2024 03:03 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Scottylt1
Jan 8, 2015 02:48 PM
cmdeshon
Dec 12, 2014 10:51 PM
Scottylt1
Dec 4, 2014 12:31 PM
