New LE2 355 Running Rough.
Old Mar 10, 2009 | 06:47 AM
  #31
gatorhead's Avatar
Originally Posted by METALBEAST
Didn't realize that. Would it not show a code though? I'll definately check that out! Thanks for the heads up!
The answer here is yes and no lol. For the temp sensor it has to be diagnosed via livescan and verifying the actual temp with a temp gun and comparing the two, there are also other methods.
With the O2's it depends again what they are or are not doing. Depending on misfunction they could or would throw a code, however if the problem is on the line side then the signal is being sent but not received and therefor you would have no codes.
Old Mar 11, 2009 | 10:11 AM
  #32
METALBEAST's Avatar
I removed the computer yesterday. I talked with Bryan Herter & he is going to look at it to make sure that I have not fried the PCM or that the program is corrupt.
Old Mar 11, 2009 | 12:15 PM
  #33
wrd1972's Avatar
I am comfortable with the tune being good. Brian usually does a good job. Maybe the Opti is on wrong, but I thought I made sure it was in the proper position when I put it on.
By any chance have you taken the opti apart?
When I built my new motor, I decided to refresh my opti with the best internal parts I had. Most people do not take one apart to the level that I did.
I pulled the cap, removed the rotor, the optical wheel and the sensor. I then pressed the two pieces apart that make up the rotating shaft that goes through the aluminum base. This is where i frigged up.
The two pieces of the shaft are not indexed which means that can back together in which way. I repacked the opti bearing with grease and pressed the two pieces of the shaft back together and paid no mind whatsoever to their original orientation which is vital for proper timing.
I installed the opti and it would not start and popped like Hell. Went round and round for hours on end and determined that I had fuel and fire. Desperate I installed a second un-tampered with near busted opti and the motor fired up and ran perfectly.
I then realized where I screwed up and in the future, when I remove the two pieces of the rotating shaft, I will scribe an indexing mark to insure the timing.
You problem to me sounds like timing.
Old Mar 12, 2009 | 02:55 PM
  #34
METALBEAST's Avatar
Hmmmm...Funny you should say that. I bought a new UNASSEMBLED Opti from a friend of mine that worked at O'Reileys. I put it together without even thinking about indexing anything. Damn! Thanks for the heads up man I'll check the Opti!
Old Mar 12, 2009 | 03:07 PM
  #35
wrd1972's Avatar
If the rotating shaft in that opti was taken apart and then re-attached for whatever reason, I will guess that is your problem. Again I did the same damn thing.
Old Mar 12, 2009 | 06:34 PM
  #36
METALBEAST's Avatar
From what you told me it sounds like it. Damnit! I told that ahole I wanted a fully assembled one when I bought it because I did NOT want to assemble it wrong Talking with a guy now who can get me a deal on a new AC Delco unit.
Old Mar 12, 2009 | 06:52 PM
  #37
METALBEAST's Avatar
So does anyone know where I can get the best price on a fully assembled AC Delco Opti?
Old Mar 12, 2009 | 07:38 PM
  #38
Stl94LT1's Avatar
Try "thepartslady" on ebay.
Old Mar 12, 2009 | 07:43 PM
  #39
wrd1972's Avatar
Sam Taylor buick cadilac in Florida.
Old Mar 12, 2009 | 09:35 PM
  #40
camzaro28's Avatar
Jason Cromer as stated by wrd1972, his number is on shbox site
Old Mar 12, 2009 | 10:29 PM
  #41
gatorhead's Avatar
Its thepartsladi on ebay. Best deal going
Old Mar 13, 2009 | 11:36 AM
  #42
87bandit's Avatar
from what I've heard sam taylor doesn't cut the best deals anymore, here's what he found out
all these are the vented.. and i was miss quoting one price it wasn't 169 it was 224..
this is summits for $224
http://store.summitracing.com/partde...5&autoview=sku
this is gm performance for $310
this is the accel for $299.95
here is the msd for $499.95
so i will say it.. don't buy from jason cromer. he may have been able to hook it up in the past but he is no longer doing much of a hook up...
he paid $396 from jason
Old Mar 13, 2009 | 12:54 PM
  #43
Nostang 96z's Avatar
My god I am so glad I moved to a crank trigger and standard distributor on my new combo. Those opti prices are insane for what you get.
Old Mar 25, 2009 | 01:52 PM
  #44
marshall93z's Avatar
Get this figured out yet?
Old Mar 25, 2009 | 03:31 PM
  #45
wrd1972's Avatar
Ouch thats a lot for a GM opti.
