maf translator tune
Old Jan 4, 2006 | 12:09 AM
94 BIGRED's Avatar
Exclamation maf translator tune
ok guy i have a maf translator and trying to get started the proble is that the conections it has were the wrong 1 so i hard wired it so when i plug it into the MAF it throws a code don't know which 1 because i have nothing to check it with. This is for a 94 Camaro LT1. The translator has 4 switches.
Switch 1: On=6 cylinder Off=8 cylinder
Switch 2: On=Old style ECM(Turbo V6,TPI V8) Off=New style PCM(LT1,LS1,SC3800,Truck
Switch 3: On=Output signal limited(blocks DTC Code 102 on OBDII vehicles)
Should also be set to ON for Grand Nation/ retrofit vehicles that are NOT running extender chips
Switch 4: 'Late model vehicles: ON=85 mm MAF on cars that were originally equipped with 3.5"
Ok iI know switches 1 & 2 should be off but what about 3&4???????
I wuld appriaciate if u guys could really help me!!!!!!!
Old Jan 4, 2006 | 11:22 AM
Zeueses 97 RamAir's Avatar
Re: maf translator tune
nobody wants to help dummy
Old Jan 4, 2006 | 12:21 PM
Seems that since you don't have OBD-II, you would leave #3 off, and since your car did not come with a 3.5" MAF that has been switched to 85mm you would leave #4 off.
Old Jan 4, 2006 | 02:14 PM
Yea I told him its better getting a new harness wouldnt u say..
Old Jan 4, 2006 | 03:59 PM
96capricemgr's Avatar
Or sell the translator and get a real tune and come out WAY WAY ahead of this halfassed crap.
Translators are useful on cars where the pcm is not easily and cheaply accessed as these are.
DirtyDaveW
Dec 1, 2016 05:37 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
