LT1 Crank Advice
Old Mar 2, 2006 | 11:15 PM
2fast97z's Avatar
LT1 Crank Advice
looking to change my crank to a stroker 383 to make my car a 390....anyone have any suggestions on a crank i should use....suggestions anyone?? mods are in my sig
Old Mar 3, 2006 | 12:50 AM
SStrokerAce's Avatar
Re: LT1 Crank Advice
A 390? do you want 390 cubes or 383?
You need pistons, rods and crank to get that done, not just a crank.
Bret
Old Mar 3, 2006 | 04:36 AM
rskrause's Avatar
Moderator
Bret
Well, with the right pistons he perhaps could re-use his rods.
Are you looking for names of good crank brands, or are you looking to buy a complete rotating assembly? Or what?
Rich
Old Mar 3, 2006 | 05:36 AM
2fast97z's Avatar
just a crank brand model...ive heard of callies dragonslayer but thats expensive as hell...and the eagle is like 299.99....i want a 383 crank but because my engine is already bored over it would be a 390.....i already have pistons and rods
Old Mar 3, 2006 | 07:46 AM
If you have a 357, its a 4.040" bore. Put a 3.75" stroke on that motor, without any more boring, and you have a "385" (actually, 384.57). To get to a "390", you'd have to use a 3.800" crank, which is what GM uses in their crate engine "383". Is that what you are after..... a 3.800" crank?
In any case, this is basic LT1 Tech, and belongs on "LT1/LT4 Engine Tech", not on Advanced Tech. Moving......
Old Mar 3, 2006 | 08:33 AM
WS Sick's Avatar
Yep Injuneers math is allways right...lol
If the 799$ dragonslayer is too pricey then you still have several choices.
The eagle 4340 forged crank (3.75 stroke 1 peice RMS) is in the 600$ range. The next step is the scat cast steel (9000 series) you can pick those up for 250$ about anywhere, After that you can try the eagle cast steel crank, it is 189$ from Summit and Jegs.
1LEThumper
Jul 14, 2003 12:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
smacz28
Aug 6, 2002 01:51 PM
