Low dyno numbers
Old Jul 25, 2013 | 04:28 AM
  #46
RamAir95TA's Avatar
Re: Low dyno numbers
Originally Posted by Shangrila
What worked in 1974 works today also, and it will work as long as combustion engines exist. When did they start stroking engines, I bet way before 1974 and people are still doing that today? Believe it or not some people stager rockers today in search of power, but I shouldn’t have to point this out to an expert like your self.
The OP claimed he wasn’t making the power he hoped for or at least on the dyno, there was nothing about engine troubles till latter. He indicated nothing other then his mechanic hearing a chirp noise. I’m not here to participate in your sausage-wagging contest, and yes, my parking/break pad was stuck on one side where it wore down to the point that it could have been used as a door wedge.
You've got to be kidding.
Old Jul 26, 2013 | 08:26 AM
  #47
What worked in 1974 works today also, and it will work as long as combustion engines exist. When did they start stroking engines, I bet way before 1974 and people are still doing that today? Believe it or not some people stager rockers today in search of power, but I shouldn%u2019t have to point this out to an expert like your self.
The OP claimed he wasn%u2019t making the power he hoped for or at least on the dyno, there was nothing about engine troubles till latter. He indicated nothing other then his mechanic hearing a chirp noise. I%u2019m not here to participate in your sausage-wagging contest, and yes, my parking/break pad was stuck on one side where it wore down to the point that it could have been used as a door wedge.
You make these totally asinine posts, everyone backs off because they know you'll have your temper tantrum like a spoiled 4-year old, and when someone finally calls you out for the unadulterated BS, this is the way you react. You are way too immature to participate in a forum like this, so I am going to put you out of your misery.
Strike 3..... you're out.
PS: brake pad
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
racecarz28
Mar 30, 2015 09:55 PM
Roadie
Feb 16, 2015 10:34 AM
YellowT/A
Aug 7, 2002 12:30 PM
Joe Brodman
Jul 24, 2002 05:24 AM
