In-Line Fuel Pump in F-Body?
Old Feb 6, 2004 | 07:27 AM
  #16
IDOXLR8's Avatar
Re: In-Line Fuel Pump Not In-tank
Originally posted by TArider21
I want to install an in-line fuel pump, not an in-tank, I need to know the parts I need for in-line install!
WHy do you want to install an inline and not an intank? I think you will be better off installing a good intank and not worrying about an inline. What is your setup?
Old Feb 6, 2004 | 09:07 AM
  #17
Do NOT try and install an in-line pump that is sucking through a non-working, or poorly working in-tank pump. It will not work correctly. An inline pump only works if there is an intank pump feeding it. Otherwise you are going to be overworking the inline pump, like trying to suck fuel through a crushed straw. And if you suck that fuel hard enough, it can vaporize in the inlet of the inline pump and really screw things up.
Adding an inline pump is NOT a good shortcut to replacing a failed in-tank pump. Do it the right way, or you will only screw up another pump.
Old Feb 13, 2004 | 10:02 PM
  #18
OBE1 95Z28's Avatar
TARider21,
Describe your symptoms to help us understand what you're trying to solve.
grabbem88
Apr 16, 2015 06:57 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
