In-Line Fuel Pump in F-Body?
Old Feb 3, 2004 | 05:00 PM
TArider21's Avatar
Question In-Line Fuel Pump in F-Body?
Is it possible to piggyback the factory fuel pump with an in-line fuel pump, and if so, how do I go about doing this? What is the most common in-line fuel pump used?
Please help!
Old Feb 3, 2004 | 06:01 PM
TArider21's Avatar
Anyone?
Old Feb 3, 2004 | 06:22 PM
OBE1 95Z28's Avatar
A TRex in-line fuel pump comes in the Vortech blower kit. The TRex supplements the stock fuel pump as it can deliver fuel under high fuel pressures that a FMU produces (80 psi).
I have since gone to a larger in-tank pump (Walbro 255 lph) as my fuel needs increased (580 rwhp) but the previous combo worked well. If you're interested in a used TRex pump, I've got one for sale...shoot me a PM.
Old Feb 3, 2004 | 06:26 PM
TArider21's Avatar
Sent you a pm OBE1!
Old Feb 4, 2004 | 12:01 AM
The NOS 5176 dry nitrous kit uses an inline pump. The original kit included a 205LPH Bosch pump, that I am still using 7 years later (although now I run it in parallel with a similar in-tank pump). The NOS install instructions show you how to put an inline pump in the stock system without cutting any lines. They also show a fairly simple electrical setup, that turns the inline pump on and off with the in-tank pump.
If you are interested, I could fax you a copy of the install instructions.
You can sort of see the install in this photo.
Old Feb 4, 2004 | 12:46 AM
Brundle's Avatar
Think holley makes one aswell, can remember the model though now....
Old Feb 4, 2004 | 07:31 PM
TArider21's Avatar
Question In-Tank Fuel Pump
If my in-tank fuel pump is going bad, would i just be waisting my time and money by installing an in-line fuel pump? Could the In-line pump bypass the factory pump altogether, or is that not possible?
Old Feb 4, 2004 | 07:48 PM
Brundle's Avatar
Re: In-Tank Fuel Pump
from what i hear u can do that if your in-tank pump has crapped out, but you'll need a reasonably strong pump to be able to push fuel through the dead in-tank one to keep up regular fuel pressure
Old Feb 5, 2004 | 06:25 AM
IDOXLR8's Avatar
I would recommend dropping the tank and installing a new fuel pump. I would suggest a Walbro 255lph if you car is pretty modded.
Old Feb 5, 2004 | 11:04 AM
Brundle's Avatar
Re: Re: In-Tank Fuel Pump
Old Feb 5, 2004 | 03:15 PM
TArider21's Avatar
Question In-Line Fuel Pump Install
What parts do I need besides the pump to complete the install? Do I need another regulator in addition to the factory regulator? Someone point me in the right direction, Please.
Old Feb 5, 2004 | 04:19 PM
TArider21's Avatar
Question
Anybody have any info for me?
Old Feb 5, 2004 | 04:40 PM
Brundle's Avatar
Re: In-Line Fuel Pump Install
buy the racetronix's setup for a walbro fuel pump, its "plug-and-play". u wont need anything else except your tools to do the job
http://www.racetronix.com/Racetronix..._Pump_Kit.html
shoulndt need another regulator unless something is wrong with the one u have now
Old Feb 5, 2004 | 05:15 PM
TArider21's Avatar
Question In-Line Fuel Pump Not In-tank
I want to install an in-line fuel pump, not an in-tank, I need to know the parts I need for in-line install!
Old Feb 5, 2004 | 08:22 PM
Z28ROC's Avatar
Injuneer offered to fax you a copy of the instructions. It has the part #s as well. He faxed me one a few years ago. All you have to do is email him.
