How does everyone like their street twin for daily driving?
Old Jun 15, 2003 | 06:27 PM
  #16
PatriotTA's Avatar
Originally posted by thewinner
hmm steel should be good or me then. im not gonna break any **** unless ive got traction correct? or does the ST just twist stuff to hell?
It depends on how you launch. I've heard of people snapping output shafts on drag radials with SPEC clutches. Obviously a dead hook launch is going to be rough on your driveline. If you don't already have an aftermarket rear 9"/12 bolt and aftermarket U-joints and driveshaft (with loops of course) I'd reccommend it.
Old Jun 15, 2003 | 06:31 PM
  #17
palehorse77's Avatar
whoa
The reason I ended my post with search for scientific reasoning (ie Dyno ot ET) was because all I had was SOTP back up. I am glad to hear that its more appropriate to have a steel unit for drag racing becuase thats all I'm really interested in. And I glad to hear that your times remained the same or got better? You said your trap speed remained unchanged. I felt as though I may have made a mistake not getting the al. fw thats all. I will check out the thread you guys are referring to.
Respectfully Kirk
Old Jun 15, 2003 | 08:23 PM
  #18
JSK333's Avatar
FWIW, I don't think having an aluminum flywheel will hurt drag racing. You just may have to dump the clutch at a higher RPM.
I have no problem melting the tires from a standing start in 1st gear with my aluminum FW, on my stock motor N/A. Same from a roll into 2nd on the nitrous (or even N/A depending on conditions).
The inertia argument is no doubt correct, but in practice, I don't think you'll notice it if you adjust your driving appropriately.
I think that any weight you can shave off the front-end, especially connected to the driveline, is generally best for drag-racing. My 0.02.
Old Jun 15, 2003 | 08:40 PM
  #19
zhevy-1's Avatar
When installed right, and I mean, no flaws afterwards, the Street Twin is a great clutch. I love mine, and I wouldn't go back to anything I've tried in the past.
I just love it!
-Goose
PS: I do have the steel flywheel. Works just fine, I haven't been able to spot any negative about having it, as supposed to having an aluminum one instead. I'm sure having the aluminum one has its advantages, the way I look at it, I don't know if it would make me any happier over the way it is right now.
Old Jun 17, 2003 | 07:53 PM
  #20
thewinner's Avatar
Do you guys recommend getting a new slave cylinder?
Its pretty much on/off clutch? No letting it out slow, once it grabs, ur going? Hows that work for reverse then?
i should be fine with the drivetrain as long as i stay on street tires right?
Old Jun 17, 2003 | 09:23 PM
  #21
thewinner's Avatar
and can you bleed the system out of the car or must it be installed to bleed?
Old Jun 19, 2003 | 05:24 PM
  #22
thewinner's Avatar
ttt
Once the car is going, is the chance of parts breaking greatly decreased? IE, if i do an easy start then punch it and go hard.
Ringmaster72
Feb 25, 2015 03:15 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
RichJ
Aug 11, 2002 10:14 PM
SABLT194
Aug 3, 2002 09:33 AM
ced8
Jun 24, 2002 11:11 AM
