Highest Mile LT1's Hollar if you hear me! Come in!
Old Aug 9, 2003 | 04:04 PM
  #91
KeVMaN's Avatar
Re: miles
Originally posted by acslinger2525
103 and she gave out. The A4 went out about 94k.
What do you mean gave out? and did you just register to say that LT1's wont last?
Old Aug 9, 2003 | 04:24 PM
  #92
acslinger2525's Avatar
Reply to that......
No i didnt just sign up just to bash the LT1, I just signed up cause i just now found the website. I love my car. I gave up a bad *** 5.0 for it. I was just replying to the person's post. The reason it went out is because it was not taken care of. To much money invested in it if it was a POS.
Old Aug 9, 2003 | 04:36 PM
  #93
KeVMaN's Avatar
Re: Reply to that......
But i don't get what you meant by "went out" What broke on the car?
edit/ Why did you put lt1 heads on an lt4? I don't even think you can do that without putting the lt1 manifold on, which would make the whole engine an lt1 (aside from the 4 bolt main)
Old Aug 9, 2003 | 05:21 PM
  #94
Zepher's Avatar
My brothers 96 T/A has a 162K miles on it and we did heads/cam on it and modded LS1's can't pull away anymore.
Old Aug 9, 2003 | 05:59 PM
  #95
elista's Avatar
124000 and all it needed was a new converter, i spun the bearing , and a fuel pump
Old Aug 9, 2003 | 06:20 PM
  #96
reply
yea, i chose that block because of the 4-bolt main and i got a heck of a deal on it. $100. I did use my LT1 intake off my car for this motor. I turned the motor about 5800 and it started knocking. I believe it should of turned this without a problem but since the oil did not get changed when it was suppose to that is why it went out. (So i will take the blame for it going out) The only bad thing about my car is when i first got it, it had a 2.73 gear in it, and those dang 5.0's 5-speed cars would leave me off the line, but i would run off and leave them when we raced from 70-up. But that was the days when i was in college, but now i can afford some upgrades.
Old Aug 9, 2003 | 09:28 PM
  #97
Mike-94 Formula's Avatar
My 91 Formula 350 isn't the same but it's at 179,000 now.I bought it in 93 and it's always had some type of synthetic oil used but never the same brand,mostly what ever was cheapest at the time.It had 50K on it when I got it and I squeeked out a best 14.03 at Twin cities then at 150k I was only able to get a best of 14.17 out of it.Amazingly it's still using mostly all original untouched parts including the motor ,trans ,rear and A/C compressor but really needs the injectors replaced.
Old Aug 10, 2003 | 04:03 AM
  #98
Patman's Avatar
For those of you with over 150k on your original LT1, what oil do you use and what viscosity? How often do you change your oil and what oil filter do you use?
I think that the LT1 likes a slightly thicker oil, so it wants something at the higher end of the 30wt range (like Amsoil, Redline, German Castrol Formula SLX 0w30) or even a 5w40 oil. As the miles get put on, the engine gets looser, so the thicker oils help protect it better. IMO, Mobil 1 is too thin if you drive your car very hard.
I also believe that if you want to get high mileage out of your LT1, don't run a K&N air filter, they let in too much dirt. A paper air filter stops a lot more dirt, and this shows in oil analysis results.
Old Aug 10, 2003 | 04:51 AM
  #99
Dmx4ever3's Avatar
i have a friend with a ss impala how ever u spell it and he had well over 300k on his lt1 i think like 360000 but im not sure may of been 315000 but its in the 300000's and he had the engine rebult with a cam and head not the big of a cam but it was i would say almost as fast as my camaro he also made the car into a m6 with the t56 tranny and are dash in the car and his clutch was very close to the floor it drive very nicely and i had a 95 camaro a4 with 166000 miles on it when i sold it i went throught 3 or maybe 4 trans and blow a head gasket 1 time and it run 14 flats all day long with intake and a flowmaster the guy i sold it to said the water pump went at 175000 and then he sold it to someone that says its the best car he ever owned and i miss that car more then any thing, i ****ed like 5 girls in that car man i was always lucky with that car but im not saying im not lucky any more just miss her so much
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jayblev95
Dec 1, 2014 06:55 AM
smacz28
Aug 6, 2002 01:51 PM
