Hesitation off idle
Old Jul 17, 2002 | 10:45 AM
  #181
aBrotze's Avatar
Post
Hey guys. This question has been talked about on the LT1 edit board. This was a year or so ago but I think the solution was to advance the timing a few degrees at ver low RPMS < 1500 when the motor is at WOT. But ya got to gave LT1 edit to do that. So in short the hesitation problem is a tunning issue.
Allen Brotze
95 firebird
LT1 edit, 58 mm
396 under construction
TB,6AL,Turbo 400, !cat,!cags,!egr,CAI, CSI electric waterpump
1 3/4 Hooker LTs
Mufflex exhuast
LCR's, Moser 12 bolt, Torque arm.
"Speed kills so you won't get hurt if you drive a Ford."
[This message has been edited by aBrotze (edited July 17, 2002).]
Old Jul 17, 2002 | 11:46 AM
  #182
Azimiut's Avatar
Post
I made a stand-off braket for my ICM and my fireball coil since it did not fit in the stock location. The ICM is not about 3" form the head. there is a noticeable gain, but still hesitation. Now I am going to go to radio shack and get some small heat sinks and maybe put them on the ICM. I will return if it works or not.
second, I am going to get the casper electronics TPS "adjuster" by this weekend and see what that does. it is supposed to advance the timming above 70% throttle off idle. summit has it. keep ya posted.
1994 Green/Grey matalic Camaro Z28 !CAGS-CAI-Ported MAF-AZSM 52mm TB-1LE Elbow-UD Pullies-Ported MAF-HI-6 + LX92 Coil-B&M Ripper-RKSport Headers-SLP Y Pipe-Random Tech Cat-Borla Cat Back-160 Therm-'98 Front Brakes-Eibach Pro Kit W/Blistein
Old Jul 17, 2002 | 12:03 PM
  #183
HEATH's Avatar
Post
IM DONE IM DONE IM DONE, I M LEAVING IN A FEW TO TAKE MINE TO THE DEALER, AND SEE IF THEY CAN SWING IT THRUE ON MY USED CAR WARRANTY>>>> ill let you all know what is diagnosed by them (if theyre any help at all??? i know the tech, so i can give him all my symptoms and trust him to run the **** out of it, and theyll keep it till its fixed WISH ME LUCK???
Old Jul 17, 2002 | 12:29 PM
  #184
Azimiut's Avatar
Post
Damn it! the TPS calibrater does not fit our cars.
Old Jul 18, 2002 | 10:56 AM
  #185
twells's Avatar
Talking
Guys
I tried one of the suggestions today and it helped. I took off my MAF and found it to be coated in dirt and grime. using windex and a q-tip i cleaned it and then wiped off my throttle body blades. id did feel a little better and i truley believe this helped my problem. at this point anything is worth a shot, so give it a try.
1995 Silver Z-28
* Black Leather, T-Tops, Bose Audio, A4 w/2.73's.
*MODS*
Ported MAF, !CAT, fan switch, !TB Coolant bypass, Hooker Longtubes, GMMG Chambered exhaust, 4" homemade CAI w/ram air scoop
* 1/4 mile- 14.372@ 98.09mph w/ 2.391 60' time (stock)
*New times to come soon!!
Old Jul 18, 2002 | 11:23 AM
  #186
guest_1845's Avatar
Cool
i did yester day too..same thing it works....i used Electronic cleaner on mine. also put screen back in. DO NOT PORT these things...the MAF Flow perfectly fine for large amounts of hp.
Old Jul 18, 2002 | 11:46 AM
  #187
Gripenfelter's Avatar
Post
It looks like you guys' hesitation is a compounded result of several different factors. No simple fix. Keep us posted.
Old Jul 18, 2002 | 12:24 PM
  #188
muckz's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by aBrotze:
Hey guys. This question has been talked about on the LT1 edit board. This was a year or so ago but I think the solution was to advance the timing a few degrees at ver low RPMS &lt; 1500 when the motor is at WOT. But ya got to gave LT1 edit to do that. So in short the hesitation problem is a tunning issue.
</font>
I started thinking that it could be timing-rekated. The reason? During loss of power at low RPMs, flooring the accelerator causes popping / missfire noises from the engine. I think advancing timing may just be the thing that we need.
The question, though, is why it's so inconsistent? Some sensor is sending incorrect data to PCM. Now, what is responsible for that? That's the million dollar question.
I also am leaning towards ICM. Definitely have to do something about heat absorption there.
Old Jul 18, 2002 | 12:46 PM
  #189
usem's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Gripenfelter:
Do you guys have any problems idling?</font>
Wow 7 pgs already. Ive been out on the topic for a few days because I just blew my engine in my Dodge so I guess my Camaro's problem will be put on hold for now...BUT
For my 94 A4, yes it does have some difficulity at idle. I am also experiencing the "popping" when I mash on the pedel. It will pop a few times before it kicks in. Also, if I am in gear at a light when the car is hot over 190 thats when the surging will occur. When I put the car in neutral everything seems to settle down but I can still hear the RPMs go up and then back down almost seems like something (ECU?) is telling it to "Click" on to raise the RPM level slightly then put it back to normal.
For now, still trying to search out this little bugger...
P.S. I changed one of my O2's then changed the fuel filter, no vaccume leaks in the elbow...
[This message has been edited by usem (edited July 18, 2002).]
Old Jul 18, 2002 | 12:59 PM
  #190
Loony-Z's Avatar
Exclamation
<font face="Verdana, Arial" size="2">Originally posted by usem:
</font>
I have that same problem, but its not what you think. Its the transmission. I have my trans go bad a few weeks ago from overheating. I was running my car pretty hard one day against some stangs(they didnt stand a chance!) and it was like 95 degrees outside. It starts revving really high and if you put it in neutral and give it a lil gas it goes down. I check my trans fluid and it said it was way hot. I'm thinkin I need a trans cooler or some better fluid.
The Lunitik
1996 White Z-28
All Stock
Never ran
Old Jul 18, 2002 | 01:02 PM
  #191
Post
If you have popping under 2000 rpm then try swapping the MAP sensor (or the harness might be loose or bad), MAF sensor, or TPS sensor.
I had a popping last year that was my MAP harness. It came loose.
Swap with a friend before you go buy one.
'93 Camaro Z28 Automatic with a ZL1 hood.
No bottle.
No blower.
383 cubic inch serving of horsepower...hold the rice please.
Thats all you need to know.
ICQ: 23984221
Gripenfelter's Homepage
Disclaimer: The opinions expressed by me are not necessarily supported or indicative of the Government of Canada or any other Federal Employee.
Old Jul 18, 2002 | 01:03 PM
  #192
Post
Do any of you have broken MAP sensor harness clips?
If it slips out it will cause your car to run badly in closed loop.
Old Jul 18, 2002 | 01:06 PM
  #193
muckz's Avatar
Post
</font>
Hmm, haven't thought about this one. Thanks for the pointer!
Old Jul 18, 2002 | 01:23 PM
  #194
phoenix64's Avatar
Post
This is why I love my 3.8. But seriously my friend has a 95 that has a serious stutter at just about any rpms. but its more pronounced at below 1500 in high gear. I've also noticed that when the car sits at idle there is a slight, and competly random pop from the exaust, every few seconds, that you can hear and feel. Its really too bad the car was really fast. but now its kind of dissapointing. Also his voltmeter sits right on the edge of the red and his idle goes from 1000-1500. please help.
Old Jul 18, 2002 | 01:26 PM
  #195
phoenix64's Avatar
Post
99, 3.8, a4, y87, cai, dxnomax exaust, 160thermo jet stage 2, fan switch, free ram air mod
