Fuel Problems :(
Old Dec 16, 2005 | 07:04 PM
joshp007's Avatar
Fuel Problems :(
Ok well I have all the mods in my sig. I got my pcm back from Ion and after I put it in the car felt like the fuel pump went out. I installed a walbro today and it still wont start. Acts like it isnt getting enough fuel. Any ideas?
Old Dec 16, 2005 | 10:27 PM
got8?'s Avatar
Re: Fuel Problems :(
Get fuel pressure readings, perhaps its your fuel pressure regulator.
Old Dec 16, 2005 | 11:31 PM
MyShibbyZ28's Avatar
Need a little more detail other than "acts like it needs more fuel".
If fuel pressure regulator, check the vacuum line for gas or the smell of gas.
If injectors lift the fuel rails up and prime the car, watch for leaky injectors
If fuel pump, well if it is not the other two it is obviously this one.
Also, I did not see injectors in your list. Maybe you need bigger ones.
Old Dec 17, 2005 | 09:53 AM
Did you check for codes? If you lose the low res pulse from the Opti (DTC 16), it shuts down the fuel system.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
