Fuel Problems :(
Fuel Problems :(
Ok well I have all the mods in my sig. I got my pcm back from Ion and after I put it in the car felt like the fuel pump went out. I installed a walbro today and it still wont start. Acts like it isnt getting enough fuel. Any ideas?
Re: Fuel Problems :(
Need a little more detail other than "acts like it needs more fuel".
If fuel pressure regulator, check the vacuum line for gas or the smell of gas.
If injectors lift the fuel rails up and prime the car, watch for leaky injectors
If fuel pump, well if it is not the other two it is obviously this one.
Also, I did not see injectors in your list. Maybe you need bigger ones.
