Can you use "used" splayed caps?
Old Dec 17, 2005 | 09:09 AM
mattbailey's Avatar
I'm starting my new project, and have found a set of used splayed caps at a good deal. Any disadvantages to using them? problems? opinions?
Old Dec 17, 2005 | 09:28 AM
96capricemgr's Avatar
Re: Can you use "used" splayed caps?
You need to have the block line hones with any change in caps, that should do it for you. First though you probably want to look into wether it is even worthwhile.
Old Dec 17, 2005 | 10:15 AM
Jason Short's Avatar
Matt, have your machine shop inspect (magnaflux) the caps before you buy them if it is possible. Any decent shop can fit used caps (as long as they are in usable/good condition). They will need to be cut then line bored/honed.
Jason
Old Dec 17, 2005 | 10:59 AM
mattbailey's Avatar
Thanks fellas.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
jayblev95
Sep 26, 2015 09:44 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
heus
Sep 8, 2015 12:01 PM
