Found this on the GM Site
Old Oct 25, 2004 | 12:39 PM
CColtManM's Avatar
What is this?... its off the GM site.
"How long should I leave the engine coolant heater plugged in during cold weather?
Usually the coolant heater should be plugged in a minimum of four hours prior to starting your vehicle. However the time may vary depending on the outside temperature, the kind of oil you have, and some other things. A dealer in the area where you'll be parking your vehicle can give you the best advice for that particular area. "
Old Oct 25, 2004 | 12:47 PM
QUASARBLUEZ28's Avatar
Re: Found this on the GM Site
I think some option included a block heater that you plug into 120v AC current in cold climates to keep the engine fluids warm. I remember My Jeep CJ had one.
Old Oct 25, 2004 | 01:10 PM
rskrause's Avatar
Moderator
I have a bracket racing buddy who uses one on his alcohol car to keep the engine temp consistent.
Rich
Old Oct 25, 2004 | 01:19 PM
IllusionalTA's Avatar
not too much expansion and contraction if everything is kept at a certain op. temp.. mostly due to clearance's w/ race car's and i know the diesel's use block heater's as well..not sure why though
Old Oct 25, 2004 | 02:18 PM
trans9_5am's Avatar
Why do diesels use block heaters? Is it because there is so much heat generated with compression that if the block temp is below a certain temp the sudden change in delta T can cause the block to gain stress cracks and eventually crack the block? I dont know just a thought but if someone knows the real answer i would like to know. After all i learn most of my information from you guys on this board
Brandon
DirtyDaveW
Dec 1, 2016 05:37 PM
DarkKnight
Buyer/Seller Feedback
May 11, 2015 10:03 PM
cmsmith
Apr 11, 2015 09:37 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
HuJass
18
Jun 24, 2002 09:19 PM
