easiest way to get the fuel pump out?
Old Oct 21, 2003 | 11:43 AM
  #16
marshall93z's Avatar
never mind man i did a search and found a picture you posted.
thanks alot
Old Oct 21, 2003 | 04:45 PM
  #17
ok this is starting to suck now. i bought a new relay and it worked for a little bit, not even enough for the car to run for 5 seconds. now all i can hear when i turn the key is a click. i have no clue now what it can be!
Old Oct 22, 2003 | 11:59 AM
  #18
UPDATE!!!!!!!!!!!!!!!
went out this morning and the fuel pump came on. took the old relay and put it back in and the damn thing still starts.
this kinda makes me not wanna go anywhere if it is just gonna quit working sometimes. pos.
maybe its a loose wire somewhere...i dunno!
Old Oct 22, 2003 | 01:05 PM
  #19
GREGG 97Z's Avatar
If you do have to replace the pump I second or third the trap door method. I just replaced mine recently, cutting the whole was very easy and the best part (or worst part) was when I was finished I had to go back in to the tank again because I f'd up the fuel level gauge! If I had dropped the rear to do it and then had to do that a second time I would have probably gone postal!
Old Oct 22, 2003 | 01:54 PM
  #20
i bet so!
Old Oct 22, 2003 | 02:00 PM
  #21
NVetro's Avatar
Even if you never did it before, the trap door will ALWAYS be easier then droping the tank. Plus you have access to your fuel system if you need to in a pinch
  #22
jonaddis84's Avatar
Might be a stupid question, but what do you do to cover the hole back up? Welding would be best, but I dont think that is the smartest place to be welding something!!!
Old Oct 22, 2003 | 02:10 PM
  #23
GREGG 97Z's Avatar
I used a piece of 22 ga sheet metal, cut it down to about 1" larger than the hole and secured it with a bead of rtv and approx 15 short (like 1/2") self tapping sheet metal screws. When I went back in again it took me about 15 minutes to get the cover off, the lines disconnected and the fuel pump back out, literally.
Old Oct 22, 2003 | 02:14 PM
  #24
jonaddis84's Avatar
Gotchya, thats what I figured the best way would be.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
