should i change my opti while the engine is out?
Old Oct 21, 2003 | 05:30 PM
wayne97's Avatar
the engine/opti has 107k on it. should I replace it? It works fine but I dont want to put it back together and then have it foul up on me. Let me know what you think...
Old Oct 21, 2003 | 05:38 PM
jkipp84's Avatar
If there's room in the engine budget, I think I'd do it just for peace of mind.
Old Oct 21, 2003 | 05:55 PM
rage366's Avatar
yep, replace it...you'll thank yourself later, grasshopper.
Old Oct 21, 2003 | 05:57 PM
TedH's Avatar
Definitely, and the water pump too.
Old Oct 21, 2003 | 06:07 PM
wayne97's Avatar
well you all seem to agree. my budget actually doesn't have room for all this, but I guess I can elininate a few other things within the budget of my daily life to make room... like electricity, food, and a few others
thanks for the input!
Old Oct 22, 2003 | 07:21 AM
IDOXLR8's Avatar
My opinion is if it ain't broke do not fix it. Opti's are prone to premature failure. I have seen brand new optis good bad within days of install.
Old Oct 22, 2003 | 02:15 PM
PGR's Avatar
PGR
Opti's are definately wear items. At 107k miles, its a good time to replace, especially if the engine is out. Do the plugs and wires too. The stock water pump isn't prone to failure like a belt driven design, but it makes sense to replace it too, since you have it off. Otherwise, the old one will probably fail and douse your new opti.
When younget a chance, disassemble the old opti, and you'll be glad you replaced it. The rotor and carbon button will be worn.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Sergio
Jan 27, 2016 04:27 PM
Alex Barnes
Jan 24, 2015 10:21 PM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Injuneer
Dec 15, 2014 09:36 AM
