Comp R's
Old Jan 15, 2006 | 03:10 PM
  #91
RPWS6's Avatar
Re: Comp R's
I think it's definetly the clips themself's that are at fault. They become unstable and unable to do there job at sustained RPM's and inproper lash setting. Thus, the loose, bouncing around and damaged result.
Old Feb 5, 2006 | 11:05 PM
  #92
foggedz's Avatar
Re: Comp R's
Originally Posted by roughneck427
also i just pulled mine out of the box being they are brand new and i noticed the theres a groove cut in the lifter to use the older style retaining clips like out of a stock lifter was thinking of taking out these tin metal retaining clips and revert to the old style keeper has anyone done this?
Not gonna work!
Old Feb 13, 2006 | 02:42 PM
  #93
gemballa996's Avatar
Re: Comp R's
is there anyway to make the clips stronger? i just called comp and they said the comp r's already have the strongest clips blah blah.
Old Feb 13, 2006 | 04:07 PM
  #94
Mkos1980's Avatar
Re: Comp R's
I hav a set but after reading this, I am thinking of reusing my stock L98 lifters. Would I be better off cleaning my old (85K) ones? My cam maxes out at 560 lift with VERY FEW runs to 6500. Usually dyno track only. Its mostly highway driven.
Old Feb 14, 2006 | 08:50 AM
  #95
roughneck427's Avatar
Re: Comp R's
yeah i went the safe route and ditched the 875-16 for some 850-16
Old Feb 16, 2006 | 11:57 AM
  #96
firebirdStud's Avatar
Re: Comp R's
so is 875-16 the part number for comp r's?
Old Feb 17, 2006 | 08:27 PM
  #97
MachinistOne's Avatar
Re: Comp R's
Just re-freshed a guy's World products Hardcore 427 all aluminum small block, half the lifter clips were in the oil pan...dont know if they were comp R's or not, but they had that same thin little retainer.
Old Feb 19, 2006 | 11:55 AM
  #98
89TramsAmGTA's Avatar
Re: Comp R's
I decided not to take any chances. I went and bought the GM lifters 2nd design for my latest build up. Not going to spin past 6200 with my XFI 218 cam and 1.6rr. The guys around here with high acceleration lift cams are running stock roller lifters with no problems. However they are shifting at or before the 6000 mark.
Old Feb 19, 2006 | 12:08 PM
  #99
Mkos1980's Avatar
Re: Comp R's
Yea. I decided to sell my comp R's and clean out my old 85K ones, since they did work perfect with the 219 cam all the way to 7000K (Only went up that high twice) But I did find a cracked one which had a crack from the bottom of the roller to the center pin of the roller. I dunno how long its been like this. I went to summit yesterday and bought 1 of their $6.50 replacement ones which are identical
Old Feb 25, 2006 | 12:42 PM
  #100
Silvershark's Avatar
Re: Comp R's
my car has been sitting all winter. I went ahead and started it up today and the passenger side valve cover was clacking like crazy. It sounds like only one is either not properly tightened down or maybe I finally have a collapsed lifter like everyone else here. These lifters have about 2000 miles on them. I guess I will talk comp into getting me a new set and then sell them on ebay and get some morels. What a pain.
Old Feb 25, 2006 | 09:12 PM
  #101
SS RRR's Avatar
Re: Comp R's
Some of these replys are just baffling to say the least. Question of the century... Why in hell would a, "stronger clip" be required when it plays absolutely no roll in the normal operation of the valve train other that to keep the plungers in place when there is no load on them?
Old Mar 2, 2006 | 01:49 AM
  #102
94z4ME's Avatar
Re: Comp R's
ahhhhhh what do you know
Old Mar 8, 2006 | 10:06 AM
  #103
bunker's Avatar
Re: Comp R's
Wow, I haven't been here for some time, but yes I've seen a few fail, mine failed right out of the box I didn't even notice it that much except I started noticing power loss past 6k rpm, so I went to re-adjust my lifters (0-lash) when I would loosen the lifters the pushrods got free right away, but one of them I kept loosening the nut and the pushrod wouldn't looen up, just kept pumping up, at that point I knew it
Old Mar 8, 2006 | 10:40 PM
  #104
SS RRR's Avatar
Re: Comp R's
Do you think that is the fault of the lifter or your zero lash setting?
Old Mar 9, 2006 | 09:37 PM
  #105
97Camaro007's Avatar
Re: Comp R's
I think that my lifter's are shot too.. which would explain the wierd problem i'm having with my car...
