Comp R's
Old Mar 12, 2006 | 07:46 AM
  #106
Jeff95TA's Avatar
Re: Comp R's
I'll throw in my $0.02. Spun a few bearings and while tearing it down, found one missing clip and one bent clip on my Comp Rs (the later thin clip design). I had preload adjusted to the Comp recommended value (I was told 0.002-0.004" preload warm; converted it to an angle based on thread size & used a protractor). I'm not going to say that it was or wasn't the fault of the lifters, just what I found.
The bent clip was "buckled" upward the same amount on opposing sides of the clip. If the cup contacted the clip I wouldn't expect it to fail like this since it should more or less contact evenly around the clip (which I don't think would cause the bending that I see), or it could shear the clip. If a pushrod contacted it, I also wouldn't expect this type of even bending.
I have buckled in quotes because that implies it was loaded in the plane of the clip and was displaced out of plane, which is what it looks like. But it really can't be loaded that way unless it was thermal growth. These clips are a full circle and don't have a break like the c-clips. If the c-clip wants to grow it has room to move. The new ones don't.
It's just a thought. I have no idea how much heat these things see or how much they want to grow relative to the lifter body. Maybe I've spent too much time at work analyzing stuff to see if it will break!
Old Mar 27, 2006 | 10:41 PM
  #107
WheelmanZ28's Avatar
Re: Comp R's
Are the Comp "R"s the same as the "Pro Magnum"? I know they are both considered the upgrade lifters for an LT1, but I don't remember if they are different names for the same product.
Old Mar 28, 2006 | 04:58 PM
  #108
Spinner's Avatar
Re: Comp R's
Yes, they're the same lifters.
Old Apr 10, 2006 | 08:15 PM
  #109
94badrag's Avatar
Re: Comp R's
The Tech at Comp Cam says the R-lifter should be used if your wanting to turn 6.5-7K RPM. These should be set with 0 lash and so require adjustment every 1-2K miles. If you don't readjust them you wind up with slop and the lifters push or pop up into the clip, since the push rod has no pressure anymore to hold it down. at this point is were the clips break. So all you have to do is maintenence and it's all cool.
Old Apr 12, 2006 | 01:34 AM
  #110
SS RRR's Avatar
Re: Comp R's
huh?
Old Apr 12, 2006 | 11:03 AM
  #111
94badrag's Avatar
Re: Comp R's
Originally Posted by SS RRR
huh?
The pressure created from the LASH. WIthout it, when the valves close the inner part of the lifter reaches the clip, since the push rod is now not pushing(no lash),with force and can crack it.
Old Apr 13, 2006 | 12:32 AM
  #112
SS RRR's Avatar
Re: Comp R's
Setting hydrolic lifters to zero lash is just down right retarded.
Every single one of those Comp help desk dolts have their own opinion as to how their parts should be installed. I swear their only qualifications is that they've watched Romper Room at least twice...
Old May 31, 2006 | 10:21 AM
  #113
user 647483's Avatar
Re: Comp R's
That's how we populate help desks
Old Jun 13, 2006 | 02:50 PM
  #114
96 WS6's Avatar
Re: Comp R's
I pulled my comp Rs out last night for some stockers. The clips all had small divots in them from the pushrod hitting. Luckily there was none lost. The car runs extremely well with the stock lifters. More power down low, smoother up top... screw comp r.
Old Jun 14, 2006 | 01:49 PM
  #115
93yellowta's Avatar
Re: Comp R's
man maybe this is my problem, I put in new comp r's.. last month when I had my h/c install... now car did not gain any power... doing some surging, but maybe not the problem, just doesn't feel strong like it should...I took off the intake to put on new gasket... and saw atleast 3 of the lifters on the driverside alone had bent divots, but didn't see any missing clips..just looked pushed in the clips did, could this be a power problem, and should I take them out before they break...I guess I can go back to stock. where is the cheapest place to buy them? and what is the easiest way to replace the lifters...thanks..
Old Jun 14, 2006 | 03:24 PM
  #116
96 WS6's Avatar
Re: Comp R's
Get those comp r's out of there stat!!! I HAD the same problems you described. I bought a set of used stockers and cleaned them out nice and good and dropped them back in. Felt like I was squeezing an extra hundred shot plus the power came on fast, strong, and stayed that way all the way to the top.
Oh and my car surged like a SOB too with the comp r's. It was very annoying...
Old Jun 15, 2006 | 05:45 AM
  #117
93yellowta's Avatar
Re: Comp R's
there coming out...what is the best way to get them out? I had these all installed... but I am sure I can get them out myself. just don't know the best way?
Old Jun 15, 2006 | 10:05 AM
  #118
93yellowta's Avatar
Re: Comp R's
update...pulled them out and 4 of them failed...clips not even in them not even in the lifter valley, I hope they went to the pan, going to change oil...they fell apart in my hands...
going to put stockers back in...
there is prob. my power loss...
Old Jun 15, 2006 | 10:08 AM
  #119
blown383's Avatar
Re: Comp R's
Is Comp Cams going to do anything about these problem!?!!?
-B
Old Jun 16, 2006 | 09:20 PM
  #120
2fast97z's Avatar
Re: Comp R's
good ole comp r's my motor blew and just went and looked closely at the lifters and 2 clips are missing and right when i grabbed them the plungers fell straight out! nice right...now definatly going the gm performance parts way
