CC306 and no tune.. How will it run? Mines going nuts!
If the gasket is bad, then its time for new ones. IF thats your problem, then the gasket is detiorated over one of the water jacket holes and its getting into the combustion chamber. Not fun, I am still trying to get my car running after that. I had to get a new motor... water washed the bearings out. Now its time for the 355ci.
Originally posted by CoUnTryMuZiCZ28
Im thinking I just need a tune.. Road Rage what do you mean pigfat? you saying i need new plugs?
Pig fat= running very rich. Check your sparkplugs, I bet they are BLACK. If you swap the plugs, and unplug the front 02's you will probably run fine until you get the tune done.
DSIM: i took the heads off and had them ported and put new head gaskets on... Except I put RTV on the head gaskets.. lol..
Road Rage:: I have a 95, only two O2s.. If I unplugged them then the car would dump fuel in and i would still run rich.. I should be getting a tune this week coming.. Whats up with that low RPM stumble?? From like 1000 to about 2000, and the idle gets low and the car almost dies when i let out the clutch..
The car thinks its running lean, so it keeps adding fuel. if you unplug your 02's it will run in open loop. Open loop is a little rich, but not much.
check plugs, if black, change plugs. unplug 02's
