CC306 and no tune.. How will it run? Mines going nuts!
Old Feb 16, 2004 | 10:43 PM
  #31
DSIM's Avatar
If the gasket is bad, then its time for new ones. IF thats your problem, then the gasket is detiorated over one of the water jacket holes and its getting into the combustion chamber. Not fun, I am still trying to get my car running after that. I had to get a new motor... water washed the bearings out. Now its time for the 355ci.
Old Feb 16, 2004 | 10:44 PM
  #32
CoUnTryMuZiCZ28's Avatar
NM... I have new head gaskets
  #33
DSIM's Avatar
Replacing means taking off the heads and putting new gaskets in.
Old Feb 16, 2004 | 10:46 PM
  #34
ROADRAGE's Avatar
Originally posted by CoUnTryMuZiCZ28
Im thinking I just need a tune.. Road Rage what do you mean pigfat? you saying i need new plugs?
Yes, you need a tune
Pig fat= running very rich. Check your sparkplugs, I bet they are BLACK. If you swap the plugs, and unplug the front 02's you will probably run fine until you get the tune done.
Old Feb 16, 2004 | 10:49 PM
  #35
DSIM: i took the heads off and had them ported and put new head gaskets on... Except I put RTV on the head gaskets.. lol..
Road Rage:: I have a 95, only two O2s.. If I unplugged them then the car would dump fuel in and i would still run rich.. I should be getting a tune this week coming.. Whats up with that low RPM stumble?? From like 1000 to about 2000, and the idle gets low and the car almost dies when i let out the clutch..
Old Feb 16, 2004 | 10:52 PM
  #36
DSIM's Avatar
So you have ported heads and cam.... yeah. time for a tune.
Old Feb 16, 2004 | 10:59 PM
  #37
ROADRAGE's Avatar
Ok, this is the last time I am going to give you this gem of advise. Check your plugs. If they are black, change them and UNPLUG YOUR 02's
The car thinks its running lean, so it keeps adding fuel. if you unplug your 02's it will run in open loop. Open loop is a little rich, but not much.
check plugs, if black, change plugs. unplug 02's
Old Feb 16, 2004 | 11:01 PM
  #38
Would all that fuel cause a rappid back fire under heavy acceleration? Or what seems to sound like it?
Old Feb 16, 2004 | 11:04 PM
  #39
ROADRAGE's Avatar
GO
PULL
A
GOD
DAM#
PLUG
Old Feb 16, 2004 | 11:05 PM
  #40
OK and what will that do? Its black yea so? Would that cause a rappid back fire?
Old Feb 16, 2004 | 11:08 PM
  #41
HAHAH I HIT 600 posts!
EDIT:: DAMM ITS 601 NOW!!
  #42
TMorgan800's Avatar
could be an exhaust leak.
Do you have a laptop and a cable from AKM for the laptop and your OBD port????
If so.. I'll give u a BIN with the CC306 Program.
Let me know.
Old Feb 16, 2004 | 11:10 PM
  #43
TMorgan800's Avatar
You could have an exhaust leak.
Also,
If you have a laptop or any computer with a serial port and an AKM cable to go between your computer and your OBD port, I will send you a CC306 file.
  #44
My friend has a laptop with the plug for my car.. But I dont think he has an edit program.. Its just like data master or something
Old Feb 16, 2004 | 11:15 PM
  #45
I dont have an exuast leak .. I made sure! lol
