cam install questions
Old Aug 2, 2007 | 12:13 PM
  #46
seawolf06's Avatar
No, they should come with the polylocks.
Old Aug 2, 2007 | 10:55 PM
  #47
OPies57's Avatar
http://www.jegs.com/webapp/wcs/store...10002_21442_-1
that the right pump
Old Aug 2, 2007 | 11:19 PM
  #48
seawolf06's Avatar
Originally Posted by OPies57
That is a stock style pump and should work. The M55A comes with the white spring already installed for higher pressure at upper RPM.
Old Aug 3, 2007 | 08:35 AM
  #49
OPies57's Avatar
no **** and that'll work with the lt1 cause the other pump (1055) is the one you listed but i missed but if that pump will work and comes with the spring thats awesome
Old Aug 3, 2007 | 08:47 AM
  #50
2QUIK6's Avatar
I'm guessing that is probably the weaker style designed pump though since its not the "Select" line of Melling pumps I posted earlier in this thread.
Old Aug 3, 2007 | 01:34 PM
  #51
seawolf06's Avatar
It works fine on plenty of cars and will work for this setup as well.
Old Aug 3, 2007 | 06:29 PM
  #52
OPies57's Avatar
yea 2quick6 i totally forgot about that, but i looked through the forum again and saw that. Thanks a lot guys
Old Aug 6, 2007 | 08:58 PM
  #53
OPies57's Avatar
http://www.jegs.com/webapp/wcs/store...10002_61726_-1
i bought these
Old Aug 7, 2007 | 05:51 PM
  #54
seawolf06's Avatar
Those will be fine. You can use your stock studs or upgrade to some ARP 3/8" studs. Also make sure your spring setup will allow for the SA rockers.
Old Aug 8, 2007 | 12:15 PM
  #55
OPies57's Avatar
i got a brand new set of 26918's from comp that are now up to spec and won't break under pressure how do i check to see if they're compatable
Old Aug 8, 2007 | 02:30 PM
  #56
Stl94LT1's Avatar
If you are going to run +.050 locks, and will probably be needed to get the correct installed heigth with those springs. You probably won't be able to use self-aligning rockers. There won't be enough valve stem for them to stay aligned.
Old Aug 9, 2007 | 11:10 PM
  #57
OPies57's Avatar
i got the seats for the springs so wont that put them at correct install height and what if i get guide plates and modify the rockers
Old Aug 23, 2007 | 04:27 PM
  #58
OPies57's Avatar
well ran into a few problems which i had expected to happen and the car started right up no problems with the self aligning rockers i actually had more room with the new springs then the older ones sounds awesome havent really beat it up yet wondering where i should shift thanks everyone for the help very much appreciated oh and i have a 93 trans am and dont have a vented optie spark very wierd
mikey4play
Mar 15, 2015 11:45 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
