cam install questions
yea i figured it'd be easier to do a whole pump but then the problem came in that i have a stock oil pan and i dont wanna suck up too much oil too fast and not have any at the bottom end, through searching people have said that its better to do just the spring with the stock pan if im wrong please correct me open to all advice
oh and what rockers should i buy and what valve covers to clear them
Don't get a high volume pump, that will suck the stock pan dry.
Here's a link to the oil pump parts/setup I determined to use with my stock pan. ...fyi, the standard Melling pumps have been known to break, so get the "Select" Melling pumps. You'll want to replace the pickup tube/screen too if you have many miles on your motor.
http://web.camaross.com/forums/showt...highlight=pump
i found these on ebay they end soon hope you guys see this http://cgi.ebay.com/ebaymotors/PRO-C...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/COMP-...spagenameZWDVW
how bout these probly a stupid question but do i need guide plates with those i know they say self aligning but just wanna have everything before my engine is torn down and i dont have something i need and with that style can i use my stock valve covers?
For the stock valve covers, you have to cut out some of the webbing structure, search around I know I saw a guide how to do this. Another alternative is to buy a set of the LT4 plastic composite covers, search shbox's web site for the part numbers..if they are still available, I bought some about a year or so ago for about $75 a side from Dal..maybe find some on ebay used...you'll also need the studs, top bolts, and gromets for them..8 of each.
