getting closer, but can't go WOT
Old Aug 23, 2007 | 03:05 PM
raroz28's Avatar
So I had a problem with my coolant temp sensor dying out and dumping tons of fuel. Killed my spark plugs.
Replaced the CTS, fixed that, and replaced the plugs because they were fouled.
Car runs so much better, idles perfect, etc... I can only give it 3/4 throttle.
If I go WOT, the car bogs out, then pulls strong, then surges more, etc... Just keeps surging, pulling.
I unplugged the o2 sensors and it didn't make a difference, just made things worse.
I was thinking I may have killed the o2's like I did my plugs.
I can't think of what could be causing it. I have a tune for the mods (bigger injectors, cam, etc...) I put in my old pcm and it runs pretty much the same, so the tune isn't bad.
I'm going to replace the plug wires, because while I had them out, some were burnt up, and I pulled terminals and swapped them on fresh wire, etc...
What else should I look at??? I am not throwing any codes. However, the check gauges light will flash, but the gauges don't do anything when it flashes. Oil pres is perfect, voltage is fine, speedo works, tach works, etc...
I guess it's a misfire. If the wires doesn't fix it, what's next?? I don't have access to any software to watch it in real time.
Old Aug 23, 2007 | 03:13 PM
Stl94LT1's Avatar
Running cats? All that raw fuel might have clogged the cats.
Old Aug 23, 2007 | 03:31 PM
joeSS97's Avatar
The O2's arent used at WOT.I am thinking your wires.Yes flashing SES is a misfire.You are getting closer.
Old Aug 23, 2007 | 04:28 PM
raroz28's Avatar
Check sig, no cats, ORY.
Joe, the ses light isn't flashing, the "check gauges" light is flashing. BUT, it does only do it when the engine is sputtering. Maybe it flashes with every misfire.
Old Aug 23, 2007 | 05:30 PM
Check the intake bellows for tears.
brothaslide
Jan 9, 2016 12:11 PM
PopoFormula
Oct 12, 2015 04:19 PM
SEOJustin
Sep 24, 2015 04:39 PM
Nellsw88
May 27, 2015 10:27 PM
jayblev95
Jan 20, 2015 01:30 PM
