355 build up ?
Old Apr 30, 2005 | 10:17 PM
raz0r6's Avatar
355 build up ?
hey guys i was just wondering what are my options or if some one can go into detail on a 355 or 357 build up would be what parts and were would i shop. i want all forged internals. i want it done right the first time so i want the best stuff inside.
thanks for the help in advanced
Old May 1, 2005 | 04:35 PM
Mindgame's Avatar
Question Re: 355 build up ?
You planning to build a normally aspirated engine or is it going to see nitrous?
I just put one together with relatively inexpensive parts. Makes close to 500 at the rear wheels and nothing's broken yet.
-Mindgame
Old May 1, 2005 | 09:44 PM
raz0r6's Avatar
Re: 355 build up ?
i do not want to run nitrous i want to be all motor i want a nice heads and cam package and intake and all the bolt ons to really bring the motor alive what should i be pushin for ill have 12 bolt out back and ill have hooker LTs into custom off road Y-pipe into a corsa cat back exhaust i want to have more then 500 rear wheel and i want to atleast run mid to high 10s.
in other words i want to pull up to a viper and give him the finger and tell him to catch me if you can
Old May 1, 2005 | 09:57 PM
raz0r6's Avatar
Re: 355 build up ?
Old May 1, 2005 | 09:59 PM
raz0r6's Avatar
Talking Re: 355 build up ?
sorry about double post damn computer....
Old May 2, 2005 | 02:48 AM
blackz97's Avatar
Re: 355 build up ?
More then 500 at the wheels? Your looking at a power adder to do that man. Either that or a serious stroker. You would probably need a nice lightweight rotating assembly, stroked 383 or 396. Some AFR heads fully worked by AI and a big nasty solid roller cam. Even with that you still might come up short, especially through a 12 bolt. What you could do is a solid 355 shortblock, have lloyd port your factory LT1 castings, and a 100 shot of juice. That would be more likely to get you 500 at the wheels then an all motor setup.
Steve
Old May 2, 2005 | 06:12 AM
Mystic97Z's Avatar
Re: 355 build up ?
500 at the wheels sounds VERY generous...i just built a 357 with all forged internals and a cam a slight bit larger than an 847 with le2 heads, and i think mine will put out around 400-420 at the wheels.
Old May 2, 2005 | 07:18 AM
rskrause's Avatar
Moderator
Re: 355 build up ?
The question is very vague. Are you looking for a turn key solution, a crate engine, or is this something you are going to do yourself? What is your budget? How do you plan to use the car? Sounds like you want a fast street car. And so on.
Rich
Old May 2, 2005 | 08:34 AM
raz0r6's Avatar
Re: 355 build up ?
everyday driver and when ever some punk *** wants to race and for me to blow him away, and some times at the track i got a 13,000 dollar loan for this swap of an lt1 and for the build up but i dont know what to buy instead of juice what about all motor plus the right supercharger setup any one now right know i have the car setup all tubular (EVERYTHING) Bmr suspension and i got the handleing and now i want the power perferably all motor. like i said i got the money and i want to do it right the first time and just be done with it and have a nice clean fast car to enjoy and drive.
kyle
Old May 2, 2005 | 08:36 AM
raz0r6's Avatar
Re: 355 build up ?
also with a nice size stall and 3:73s what do i really need to have with out Juice to run mid to high 10s.
Old May 2, 2005 | 11:34 AM
Snakebyt's Avatar
Re: 355 build up ?
if you want all motor, defenatly stroke it, but if you are looking for 10 sec timeslips, you are going to need some juice. a well built fully forged motor can take 200-300 easy if it is done right
Old May 2, 2005 | 05:40 PM
95Bird's Avatar
Re: 355 build up ?
10s on motor is not easy. If your wanting to keep it 100 percent street car better go power adder.
Old May 2, 2005 | 05:59 PM
Mindgame's Avatar
Re: 355 build up ?
Just watch out so that the "punk asses" don't think YOU'RE the "punk ***".
All kidding aside, 'bird is right.... it aint easy and Mystic is right too... a GM 847 won't get you there. It is possible NA... you just need the right top end and then you need the real hard part of the equation... the right suspension/car setup.
With your budget, it won't work..... not the way I'd want to build it anyways. That said, I'd shoot for a 400-425 rwhp build and put the juice to it in vast quantities.
-Mindgame
Old May 2, 2005 | 06:33 PM
Bow94z's Avatar
Re: 355 build up ?
Originally Posted by Mindgame
Just watch out so that the "punk asses" don't think YOU'RE the "punk ***". -Mindgame
I was thinking the same thing
yea sooo back to the topic...
Old May 2, 2005 | 08:05 PM
marshall93z's Avatar
Re: 355 build up ?
-Mindgame
are you saying that 13,000 wont get him 500 rwhp on motor? or are you talking 18º stuff?
